Automation Hub user guide
Customize idea flows
Create and customize idea flows in Automation Hub on Automation Suite, configuring categories and steps for employee-driven, CoE-driven, and other submission paths.
The default idea flows available are:
  • Employee-driven idea
  • CoE driven idea
  • Citizen Developer automation
  • Process Mining idea
  • Change request
All the default idea flows are structured under All categories. The System Admin can create new idea flows under All Categories or select a different category as needed and add a specific flow.
Note:
  • When the customize idea flow feature becomes available, customers who had assessments per category created will now have each assessment migrated under its specific flow built on a specific business area.
To create a new specific category, follow the steps below:
  • In Admin Console > Platform Setup > Customize idea flows select the Category dropdown.
  • Select New category segment.
  • From the new window, choose from the dropdown list what category you want to have segmented and Confirm.
  • A new category is now created and you can start a New idea flow and pick one of the following options:
    • Copy existing: Duplicate and build from any other flow in your tenant.
    • Duplicate a default: Start with one of the Automation Hub default idea flows.
    • Upload: Upload an idea flow that was previously downloaded from another tenant.
For every specific Category, you can choose if the Idea flow is live or offline by using the Disable for action. To disable a flow, select the three dotted menu form the Idea flow and select Disable for (category) action. This impacts the available flows when business users Submit an idea.
Figure 1.
Tip:
Enable/disable an idea flow: If you want for a user to see only the idea flows under Production category when submitting an idea where the Production Business Area is selected, you need to disable the flows from higher levels.
In the new created specific Category, you will also find the list of idea flows defined under the parent category segments. You need to enable or disable them based on your needs for your newly created specific category.
For each category selected, you can find cards representing idea flows defined for the current category. Below, in separate sections, you can have cards representing idea flows defined from all categorie segments available.
Example: If you have a category with three segments: Legal / eDiscovery and Research / Production and you choose to add or modify an idea flow for Legal / eDiscovery and Research / Production segment, below, in separate sections, you can have:
  • section with idea flows from All categories.
  • another section with idea flows from Legal (if any defined at this level).
  • another section with idea flows from Legal / eDiscovery and Research (if any defined at this level).
Note:
  • Pre-migration assessments that were created on categories had the same name (e.g. Default assessment). After migration, to differentiate between the versions, assessment will use the following naming convention: + ; (e.g. Default Assessment Legal).
  • Assessments that are already created on a specific category segment are migrated to Customize assessments, without being split on categories and the system creates new idea flows on the specific category segment.
New idea flow and how to set a live version​
To create a new idea flow follow the steps below:
  • Select New idea flow.
  • Copy an existing flow, duplicate a default one or upload a downloaded one (in .ahw format).
  • If copy existing is selected, you need to choose a category from where to import.
  • Select an existing flow.
    Note:
    If you choose to upload a downloaded idea flow, you can skip the below steps and continue with Idea flow settings.
Now you can modify the following:
  1. Idea flow title: The idea flow title that's displayed to submitters in the submission forms - Idea type dropdown
  2. Idea flow description: Add a description to your idea flow
In Assessment visibility section:
  1. 6 dotted menu - Assessments reorder : Arrange the lineup of the assessments in the workflow. - decide which assessment types you need in the flow
  2. Live Version: You can select the assessment version needed in the custom idea flow.
    Note:
    Once a certain assessment version has been selected, the submitter of the idea will see that assessment version as part of the Submission form and/or the Automation Profile page.
  3. Phase: Select the list of phases in which the assessment type is visible.
  4. Delete: You can delete a specific assessment if it's not needed in the current custom idea flow.
  5. Add a new assessment: You can add a specific assessment type and version available.
    Note:
    The Overview Assessment must always be first and cannot be moved. Also, the phases cannot be enabled or disabled.
Admins can change the details of an existing idea flow anytime, but you must take in consideration the following:
  • If the version for an assessment in the ‘Live version’ dropdown is changed, then the new ideas submitted on that flow will show the new version of assessment selected and existing ideas linked to that flow will continue to show the initial assessment version.
  • If the phases where an assessment needs to be displayed in are changed, then the new ideas submitted on that flow will have that assessment in the newly specified phases and existing ideas linked to that flow will also reflect the phase changes and show/hide assessments as per the new settings.
Configuring a business process idea flow​
Mark an idea flow as a Business Process idea flow to make it available when users submit business processes.
Automation Hub groups idea flows into three categories — Ideas, Change requests, and Business processes — based on their settings. Idea flows marked as business process flows appear as options only when a user selects Business process on the submission screen. An idea flow that is not marked as a change request or business process flow is grouped under Ideas by default.
Prerequisites​
  • You have the Account Owner or System Admin role.
  • The idea flow you want to configure already exists in Automation Hub.
  1. Go to Admin Console and select Platform Setup.
  2. Select Customize Idea Flows.
  3. Open the idea flow you want to configure.
  4. Select the Settings tab.
  5. Enable the This is a business process idea flow option.
  6. Select Save.
Results​
The idea flow is now categorized as a business process flow. It appears as an option when users select Business process on the submission screen and choose the category this idea flow belongs to.
  • New idea flow and how to set a live version​
  • Configuring a business process idea flow​
  • Prerequisites​
  • Results​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
