Automation Hub API guide
Introduction to Automation Hub API
Automation Hub Open API capabilities for Automation Suite 2.2510, covering programmatic access to tenant data and available request categories.
The Open API feature allows UiPath Automation Hub users to access and manipulate their tenant data programmatically. Based on the feedback received, as well as the platform structure, we've focused on delivering API requests as in below examples:
Note:
  • The entire API calls list can be found in Swagger and Postman documentation.
  • Some quick examples on how to use API calls can be found in Examples of API Calls. For an in-depth experience or to test specific API responses, use the Swagger or Postman environment described in API References.
Customized Assessments​
  • GET/idea-schema
  • POST/idea-from-schema
  • GET/automations/{automationId}/schema
  • PATCH/automations/{automationId}
Automation Ideas​
  • GET/automations
  • GET/automations/collaborators
  • DELETE/automations/{automationId}/collaborators
  • POST/automations/{automationId}/collaborators
  • GET/automations/{automationId}/documents
  • POST/automations/{automationId}/documents
  • GET/automations/{automationId}/components
  • GET/questionnaire
  • GET/cba
  • PUT/automations/cba/{automationId}/project-plan-baseline
  • POST/automationidea
  • POST/coe-automationidea
  • POST/processmining-idea
  • POST/automations/{automationId}/media
  • POST/automations/status
  • POST/automations/{automationId}/tags
  • PUT/automation/{automationId}/categories
Automation Pipeline​
  • GET/automationpipeline
Users​
  • GET/users
  • GET/roles
  • POST/adduser
  • POST/edituser
Application Inventory​
  • GET/appinventory
  • PUT/appinventory
  • DELETE/appinventory/{applicationId}
Categories​
  • GET/hierarchy
  • PUT/categories
Components​
  • GET/components
Automation Store​
  • GET/automation-store
  • GET/automation-store/{automationId}/reviews
The API calls reflects actions that a user can perform in the Automation Hub interface.
To start making calls with the following variables access the OpenAPI options from the Automation Hub platform > Admin Console > Platform Setup > Open API and generate your token.
VariableValue
TokenThe token generated from the Automation Hub UI.
URLhttps://{yourDomain}/automationhub_/api/v1/openapi
Delayed Release URLhttps://{yourDomain}/automationhub_/api/v1/openapi
GET all ideas API structure for Delayed Release Organizationshttps://{yourDomain}/automationhub_/api/v1/openapi
App keyThe app key generated from the Automation Hub UI.
Note:
{orgName} and {tenantName} are variables that refer to the name of your organization and the name of your tenant.
The next step is to Consume the available APIs.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
