Automation Hub API guide
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Input for Users
User role input values for Automation Hub API calls in Automation Suite 2.2510, covering default platform roles and how to retrieve custom role keys.
Note:
Below you can find the value for the platform default/uneditable roles. To assign a customized role please use first the Get user roles call in order to find out the key value.
| Key | Value | Use Case |
| user_email | The email address of a user who does not have an account in Automation Hub/who's account is to be updated. | GET and POST request parameters |
| user_first_name | The first name of the user that is about to be added/edited. | GET and POST request parameters |
| user_last_name | The last name of the user that is about to be added/edited. | GET and POST request parameters |
| user_job_title | The job title of the user that is about to be added/edited. | GET and POST request parameters |
| user_business_unit | The business unit of the user that is about to be added/edited. | GET and POST request parameters |
| user_department | The department of the user that is about to be added/edited. | GET and POST request parameters |
| user_location | The location of the user that is about to be added/edited. | POST request parameter. |
| inviteStatus | inviteStatus=all inviteStatus=active inviteStatus=inactive inviteStatus=pending | GET filter |
| user_roles | System Admin = 2 RPA Sponsor = 3 Component Curator = 4 Program Manager = 5 Idea Approver = 6 Standard User = 8 Project Manager = 11 | POST request parameter. |
| category_id | You can easily extract Category ID by using the GET category call. | POST request parameter. |
UI Correspondent: Completing the Add User Form
