Automation Hub API guide
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Input parameters for the Cost Benefit Analysis API call in Automation Hub 2.2510 on Automation Suite, requiring the automation ID from a GET ideas call.
| Key | Value | Use Case |
| id | The idea identification number. | GET request parameter |
Note:
To retrieve the automation ID you first need to make a GET automation idea call.
Example: id=29
