Automation Hub
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
Automation Hub API Guide
Last updated Sep 19, 2023
Key |
Value |
Use Case |
id |
The idea identification number. |
GET request parameter |
Note:
To retrieve the automation ID you first need to make a GET automation idea call.
Example: id=29
