2022.4
Automation Hub API Guide
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Input for Users
Note:
Below you can find the value for the platform default/uneditable roles. To assign a customized role please use first the Get user roles call in order to find out the key value.
| Key | Value | Use Case |
| user_email | The email address of a user who does not have an account in Automation Hub/who's account is to be updated. | GET and POST request parameters |
| user_first_name | The first name of the user that is about to be added/edited. | GET and POST request parameters |
| user_last_name | The last name of the user that is about to be added/edited. | GET and POST request parameters |
| user_job_title | The job title of the user that is about to be added/edited. | GET and POST request parameters |
| user_business_unit | The business unit of the user that is about to be added/edited. | GET and POST request parameters |
| user_department | The department of the user that is about to be added/edited. | GET and POST request parameters |
| user_location | The location of the user that is about to be added/edited. | POST request parameter. |
| inviteStatus | inviteStatus=all inviteStatus=active inviteStatus=inactive inviteStatus=pending | GET filter |
| user_roles | System Admin = 2 RPA Sponsor = 3 Component Curator = 4 Program Manager = 5 Idea Approver = 6 Standard User = 8 Project Manager = 11 | POST request parameter. |
| category_id | You can easily extract Category ID by using the GET category call. | POST request parameter. |
UI Correspondent: Completing the Add User Form
