- Getting started
- Data security and compliance
- Organizations
- Authentication and security
- Licensing
- About licensing
- Unified Pricing: Licensing plan framework
- Flex: Licensing plan framework
- Activating your Enterprise license
- License migration
- Assigning licenses to tenants
- Assigning user licenses
- Deallocating user licenses
- Monitoring license allocation
- License overallocation
- Licensing notifications
- User license management
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Automation Cloud Public Sector admin guide
To create a VPN gateway for a tenant:
The panel closes and the VPN gateway status is Provisioning.
When complete, the status Deployed is displayed on the card of the gateway.
The Vnet for a cloud robot template is created when each template is created.
Cloud robots - VM
In Orchestrator, create one or more Cloud robot - VM pools, following the instructions in Creating the cloud robot pool . During setup, make sure to select the Connect VPN Gateway option.
For each pool, you can monitor the VPN status from the Machines > Manage Cloud Robot - VM page.
Existing Cloud robot - VM pools cannot connect to the VPN gateway. You must create new ones.
Additionally, for pools that were set up to connect to the tenant's VPN gateway, you have the option to edit the pool and switch off the Enable VPN Integration toggle to disconnect the pool. Once disconnected, you cannot reconnect the pool to the VPN gateway.
Cloud robots - serverless
With the VPN gateway deployed, you can now connect your on-premises networks to it.
The gateway card displays the public IP address, which is an essential information for the tunnel connection.
To configure the VPN gateway to connect to a VPN device:
The panel closes and the new connection is displayed on the Connections page. The connection is ready to use when the Connection status column displays Connected.
A Connected status means the Pre-Shared Key (PSK), peer Public Internet Protocol (IP) address, and IPSec/IKE Policy parameters are configured correctly, and an encrypted tunnel exists.
Serverless and Cloud Robots inherently do not accept incoming network connections. An exception exists for Cloud Robots, which allow Remote Desktop Protocol (RDP) connections only when explicitly enabled.
To add more connections, on the Connections page, select Create connection.
