automation-cloud-public-sector
- Getting started
- Data security and compliance
- Organizations
- Authentication and security
- Understanding authentication models
- Setting up the Azure AD integration
- Setting up SAML SSO with Azure AD
- Setting up Okta as your identity provider
- Setting up PingOne as your identity provider
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Cloud for Public Sector Admin Guide
Last updated Oct 4, 2024
Note: The instructions in this section are for a sample configuration. For more information about any IdP settings not covered
here, please use the
PingOne documentation
- In a different browser tab, log in to the Ping One Admin Console.
- Go to Connections > Applications, and select the plus icon +.
- Select Web App, and for SAML select Configure.
- On the Create App Profile page, specify a name for your UiPath app.
On the Configure SAML Connection page, select Manually Enter and provide the following details:
- ACS URLs: Enter the Assertion Consumer Service URL value you got from the UiPath platform.
- Entity ID: Enter the Entity ID value you got from the UiPath platform.
- SLO binding:HTTP Redirect
- Assertion Validity Duration: Enter the number of seconds for the validity period.
- Select Save and Continue.
- On the Map Attributes page, add the email address:
- Select + Add Attribute.
- For Application Attribute, enter
http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress
. Thehttp://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress
claim is case-sensitive. - Set Outgoing Value to Email Address, or the user attribute that contains the user's unique email address.
- Select the Required checkbox.
- Optionally add other attribute mappings. UiPath also supports the First Name, Last Name, Job Title, and Department user attributes. The attributes are case sensitive. This information is then propagated to the UiPath platform, where it can be made available to other services, such as Automation Hub.
- Select Save and Close.
- Turn on the toggle for the UiPath app to enable the application for user access.
- On the Configuration tab, copy and save the IdP Metadata URL value for later use.
