ai-center
AI Center Installation Guide
- Getting Started
- Network requirements
- Single-node requirements and installation
- Multi-node requirements and installation
- Accessing AI Center
- Provision an AI Center tenant
- Updating Orchestrator and Identity Server certificates
- Resizing PVC
- Adding a new node to the cluster
- ML packages offline installation
- Configuring the Cluster
- Configuring the FQDN post-installation
- Backing up and Restoring the Cluster
- Using the Monitoring Stack
- Setting up a Kerberos Authentication
- Provisioning a GPU
- Using the configuration file
- Node scheduling
- Migration and Upgrade
- Basic Troubleshooting Guide
After the installation is complete, follow the instructions from this guide.
Important:
The AI Center standalone installation uses the same installer as Automation Suite. Some pages from the Post-installation section can lead to the corresponding page in the Automation Suite. In this situation, the steps are the same in both situations and there are no particularities in the specific procedure for AI Center.
Make sure that you follow the procedure suited to your needs.
