ai-center
AI Center Installation Guide
- Getting Started
- Network requirements
- Single-node requirements and installation
- Multi-node requirements and installation
- Accessing AI Center
- Provision an AI Center tenant
- Updating Orchestrator and Identity Server certificates
- Resizing PVC
- Adding a new node to the cluster
- ML packages offline installation
- Configuring the Cluster
- Configuring the FQDN post-installation
- Backing up and Restoring the Cluster
- Using the Monitoring Stack
- Setting up a Kerberos Authentication
- Provisioning a GPU
- Using the configuration file
- Node scheduling
- Migration and Upgrade
- Basic Troubleshooting Guide
Offline single-node installation
Use the following steps to install AI Center on a single machine in an airgapped environment with no access to the internet. If deploying an environment where the machines have internet access we recommend using the online installation steps which are optimized for that case.
Prerequisites
Hardware and software prerequisites must be completed before proceeding with the installation.
