- 入门指南
- 主机管理
- 组织
- 租户和服务
- 身份验证和安全性
- 许可
- 帐户和角色
- 外部应用程序
- 通知
- 日志记录
- 故障排除
关于 Automation Suite
Automation Suite is the self-hosted UiPath business platform that allows you to manage multiple UiPath products as one integrated solution. It provides a comprehensive set of tools and services for end-to-end automation, including process mining, document understanding, task mining, test management, and more. Automation Suite offers flexibility in deployment options, allowing you to install it on-premises or in the cloud. With Automation Suite, you can enable or disable specific products based on your needs.
Automation Suite includes the following:
All server products, except for any new products shipping in Automation Cloud first.
All shared suite capabilities that enable you to easily configure the integration with existing enterprise systems, such as AD, AAD, or SAML, across all products. We offer a common experience across the suite for the user, tenant, external applications, and license management.
通用最终用户门户。
This guide offers extensive instructions to cater to varying needs. For end users, it provides general documentation on how to use and navigate the Automation Suite portal. For administrators, the guide provides documentation on how to set up the organization security, authentication, licensing, and other configurations.
UiPath Platform 包含各种旨在自动化流程、增强协作并提高运营效率的产品:
Action Center
UiPath Action Center 是一个工具,旨在帮助您管理和解决自动化工作流中需要人工干预的异常、错误或决策。 它提供了一个用于处理这些异常的集中界面,允许人工根据需要进行审核、制定决策和采取操作,以确保成功完成自动化流程。
Automation Ops
UiPath Automation Ops 工具可用于根据用户配置文件管理和实施监管策略,以及管理组织中可用的订阅源。
Data Service
UiPath Data Service 是一项持久性数据存储服务,可为自动化项目提供无代码数据建模和存储功能。
Document Understanding
UiPath Document Understanding 使用预定义的解决方案对常见文档类型中的数据进行提取和分类。 使用预训练模型,它可以轻松从标准文档中提取信息。
Insights
UiPath Insights 工具可用作数据建模和分析的平台,该工具结合使用可用的业务指标和对自动化和机器人性能的运营见解。
Orchestrator
UiPath Orchestrator 是一款用于简化自动化流程和机器人的部署、监控和监管的工具,让您可以根据要求灵活地计划和触发这些流程。 它还支持管理事务数据,这些数据通常用于自动化业务流程。
UiPath™ Identity Server 是一项服务,可跨 UiPath 产品提供集中式身份验证和访问控制。其目的是为所有 UiPath 产品和服务的身份验证以及授权的某些方面提供一致的体验和同等的功能。对于 Identity Server,这些产品和服务被视为客户端。
通过与 Identity Server 的集成,其客户端将拥有共享的启动和用户管理体验。在后台,通过 Identity Server 执行身份验证,该服务器提供 SSO 体验,并生成令牌以通过 API 与其他产品通信。用户登录后,Identity Server 将在访问其他产品或服务时无缝执行调用。注销体验与此类似:用户注销一个客户端后,Identity Server 就会对所有其他客户端执行注销调用。
Identity Server 还充当联合网关,支持外部身份提供程序,使其客户端应用程序可以轻松连接到这些外部提供程序。
Identity Server 提供身份验证即服务,其中包含所有集成应用程序的集中式登录逻辑和工作流,从而使服务更易于通过标准协议系列 OAuth 相互集成。它基于 IdentityServer4 开源库,内置在 .NET Core 3.1 中,并支持 OpenID Connect 和 OAuth 2.0 框架。
