test-suite
OUT OF SUPPORT
Test Suite User Guide
Last updated May 14, 2025
Mobile device automation
This section describes the Mobile Device Automation solution in more detail, and helps you in getting started on how to use it.
About mobile device automation
Mobile device automation involves using three distinct components:
  • Studio - IDE for designing mobile tests, and prepare them for test management and execution.
  • Mobile Automation activities - Configurable actions that you can take on the mobile device, to automate it.
  • MDM (Mobile Device Manager) - Tool that offers you a realistic visual interface of testing and automating a mobile device within Studio. You can use MDM to connect to real or emulated devices through Appium, and perform and record your actions on the device as well as manage devices and applications.
Resources
To get started with using UiPath®'s mobile device automation solution, check out the following resources:
