- Getting started
- Data security and compliance
- Organizations
- Authentication and security
- Licensing
- About licensing
- Unified Pricing: Licensing plan framework
- Activating your Enterprise license
- Migrate from Test Suite to Test Cloud
- License migration
- Assigning licenses to tenants
- Assigning user licenses
- Deallocating user licenses
- Monitoring license allocation
- License overallocation
- Licensing notifications
- User license management
- Tenants and services
- Accounts and roles
- Access policies
- AI Trust Layer
- External applications
- Notifications
- Logging
- Data Export
- Testing in your organization
- Troubleshooting
- Migrating to Test Cloud
AI features and model routing
AI features and model routing in Test Cloud, covering the third-party LLMs used by UiPath services and how requests are routed across hosting regions.
Some UiPath services use AI-powered capabilities delivered through third-party large language models (LLMs), including the GPT family (via Azure OpenAI Service), Gemini models (via Google Vertex AI), Claude models (via Amazon Bedrock), and Kimi models (via Fireworks AI).
These models are hosted in specific regions. When an LLM endpoint is not available in the same region as your UiPath organization or tenant, data is temporarily routed to a region with an available model endpoint.
UiPath does not control the geographic availability of third-party LLMs. However, once a third-party provider makes a new model region available, UiPath investigates and works toward supporting that region for its AI-powered features, while continuing to define only the routing behavior.
How data is processed
When you use an AI feature, the data path depends on three separate regions:
| Region types | Description | Who controls it |
| Organization region | The region where your UiPath organization is provisioned. The organization region is considered for services enabled at the organizational level, that inherit the organization region (for example, Apps, Automation Ops, and Studio Web). | You choose the organization region when you create the organization. An organization region is not visible in the UI. |
| Tenant region | The region where a tenant-level service (for example, Orchestrator, Test Manager, or Agents) is hosted and processes data. | You choose the tenant region when you create the tenant. A tenant’s region is visible in the UI, from the tenant dropdown. |
| LLM processing region | The region where the third-party model actually runs. | Determined by the third-party LLM provider, which defines where an LLM endpoint is available. If an endpoint is not available in the organization or tenant region, UiPath may temporarily route the request to another supported region. When a new LLM region becomes available, UiPath evaluates and works toward supporting it, while continuing to define only the routing behavior. |
These regions can differ. While your UiPath data remains in your selected organization or tenant region, data used when working with AI features may be temporarily routed to another region for model processing if no local LLM endpoint exists.
You can restrict LLM processing to specific regions with the Model Regions tab of an AI Trust Layer policy in Automation Ops. When regions are restricted, LLM traffic is routed only to the selected regions, and requests to models that are not available there fail. For details, see Model Regions.
AI features residency
Check the following definitions to understand the residency scopes used when working with UiPath’s AI features:
- Organization region: The geographic region you select when creating your UiPath organization. This determines where your organization data is stored, including the data for services that inherit the organization region. Such services are marked as Organization-level in the Global cloud regions table.
- Tenant region: The region where a tenant is hosted and where its services (for example, Orchestrator, Test Manager, or Agents) operate. Services that inherit the tenant region are marked as Tenant-level in the Global cloud regions table.
- Service region: The region where a specific service within an organization or tenant runs. In most cases, all services in a tenant follow the tenant region, but some follow the organization region. The data residency of a service is marked in the Global cloud regions table as either inheriting the organization region or tenant region, along with its availability across cloud regions.
- LLM model endpoint region: The region where the third-party large language model (LLM) executes data processing. The availability of LLM regions is determined by the third-party provider (for example, Azure OpenAI, Google Gemini, or Anthropic Claude). UiPath defines routing rules only when a model is unavailable in the selected tenant or organization region.
- Global deployment (LLM): A deployment type in which the model is not tied to any specific geographic endpoint. Requests are processed in a vendor-selected region based on availability, and there is no guaranteed LLM processing region. When strict data residency requirements are enforced, globally deployed models are not available.
AI residency example
The following example shows how data is handled across regions when using UiPath services that include AI features. It highlights the different residency scopes involved, and explains how data is processed.
| Scenario | Description | |
| Organization region | European Union (EU) | N/A |
| Tenant region | EU | N/A |
| Services used |
| N/A |
| Model availability |
| N/A |
| LLM processing region | The LLM processing region is the same as the organization and tenant region: EU. All data is hosted and processed in the same region. | N/A |
If the organization or tenant is located in a region where a third-party provider does not offer an LLM endpoint, the request is routed to a region where an endpoint is available. Once the model response is returned, all further data processing continues within the organization’s or tenant’s region.
Models consumed by Autopilot
Some UiPath services use AI models that are consumed through Autopilot, alongside other proprietary AI capabilities specific to those services. Because Autopilot capabilities are shared across multiple UiPath services, we document Autopilot-consumed models by Autopilot type to clearly indicate how models are used, reused, and routed.
Categorizing models by Autopilot type helps you understand which Autopilot capability consumes a given model and how the same model may be reused across multiple services.
The following Autopilot types are used when documenting model consumption:
- Autopilot: Represents Autopilot as a coding agent, the current, recommended experience for creating UiPath artifacts and implementations through natural-language conversation. Currently, Autopilot is surfaced in the following services: Studio Desktop, and VS Code-compatible editors (Public Preview).
Earlier Autopilot capabilities are the capability sets that preceded the coding agent:
- Autopilot actions: Represents fixed, pre-defined operations triggered from the UI, with no conversation or session context. Currently, Autopilot actions is surfaced in the following services: Apps, Maestro, ScreenPlay, Studio, Studio Web, and Test Manager. In Test Manager, Autopilot actions generates, refactors, and analyzes test cases from a single natural-language prompt — see Autopilot actions in Test Manager for details.
- Autopilot search: Represents one-shot, natural-language retrieval, with no multi-step conversation. Currently, Autopilot search is surfaced in the following services: Orchestrator, Action Center, and Test Manager.
- Autopilot agent: Represents the multi-turn conversational assistant that preceded the coding agent, drawing on the same underlying models as Autopilot. Currently, Autopilot agent is surfaced in the following services: Studio Web, Test Manager, and Studio Desktop.
Model routings by service
Each UiPath service that uses AI models defines its own routing rules. These rules apply only when an LLM endpoint is not available in the organization or tenant region, and not when a request to an available endpoint fails. If a call to an available endpoint fails, retry the action.
When routing is triggered, UiPath temporarily changes the LLM processing region to another region where the model is available. Only the model processing takes place in the routing region. After the model returns its response, all remaining data processing continues in the organization or tenant region.
The following tables list the routing behavior for each service when an LLM endpoint is not regionally available.
If a service does not have a section with LLMs on this page, it does not have features that use LLMs. It can still integrate with other services that use LLMs, which are documented in the sections below.
For current model lifecycle stages, see LLM model lifecycle. For retirement announcements and migration dates, see LLM model deprecation timeline.
Legend
- AU - Australia
- CA - Canada
- CH - Switzerland
- EU - European Union
- IN - India
- JA - Japan
- SI - Singapore
- SK - South Korea
- UAE - United Arab Emirates
- UK - United Kingdom
- US - United States
Agents
Conversational agents use the same LLMs and routing as Agents, so the table below also applies to them.
| Feature | Model | LLM provider | AU | CA | CH | EU | IN | JA | SI | SK | UAE | UK | US |
| Design, Evaluate & Deploy | claude-opus-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-3.7-flash | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.6-sol | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gpt-5.6-terra | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gpt-5.6-luna | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| anthropic.claude-sonnet-5 | Amazon Bedrock | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Stays in the region | |
| anthropic.claude-opus-4-8 | Amazon Bedrock | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to US | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| anthropic.claude-opus-4-7 | Amazon Bedrock | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| anthropic.claude-sonnet-4-6 | Amazon Bedrock | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| anthropic.claude-opus-4-6-v1 | Amazon Bedrock | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gemini-3.5-flash | Google Vertex AI | Routed to US | Stays in the region | Routed to EU | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | Stays in the region | Stays in the region | |
| gemini-3.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.5-2026-04-23 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gpt-5.4-mini-2026-03-17 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.4 | Azure OpenAI Service | Routed to US | Routed to US | Routed to US | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to US | Routed to US | Routed to EU | Stays in the region | |
| gemini-3.1-pro-preview — Public Preview | Google Vertex AI | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | |
| anthropic.claude-haiku-4-5-20251001-v1:0 | Amazon Bedrock | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| anthropic.claude-sonnet-4-5-20250929-v1:0 | Amazon Bedrock | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.2-2025-12-11 | Azure OpenAI Service | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Stays in the region | |
| gpt-5.1-2025-11-13 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gemini-3-flash-preview — Public Preview | Google Vertex AI | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Stays in the region | |
| gpt-5-2025-08-07 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5-mini-2025-08-07 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gemini-2.5-pro | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gemini-2.5-flash | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4.1-2025-04-14 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4.1-mini-2025-04-14 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4o-2024-11-20 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to US | Routed to EU | Routed to EU | Stays in the region | Stays in the region | |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4o-mini-2024-07-18 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| LLM as Judge guardrail | gemini-3.7-flash | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
Apps
| gemini-2.5-flash | Google Vertex AI | Routed to EU | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Stays in the region |
| gpt-4o-2024-11-20 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Stays in the region |
Autopilot
| claude-opus-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| claude-sonnet-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| fw-kimi-k3 | Fireworks AI | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Stays in the region |
| gpt-6-luna | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region |
| gemini-3.6-flash — Upcoming removal: 2026-11-19 — Replacement: gemini-3.8-flash | Google Vertex AI | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL |
Autopilot Actions
| anthropic.claude-3-7-sonnet-20250219-v1:0 | Amazon Bedrock | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | N/A | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 |
| gemini-2.5-pro | Google Vertex AI | Routed to EU | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-2.5-flash | Google Vertex AI | Routed to EU | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Stays in the region |
| gemini-2.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gemini-2.5-flash | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-4.1-mini-2025-04-14 | Azure OpenAI Service | Routed to US | Routed to US | N/A | Stays in the region | Routed to EU | Routed to US | Routed to EU | N/A | N/A | Routed to EU | Stays in the region |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Routed to JA, as gpt-4o-2024-11-20 | Routed to US | Routed to EU | Stays in the region | Routed to JA, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to JA, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-embedding-001 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
Autopilot for Everyone
| deepgram-flux-general-en | Deepgram | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| deepgram-flux-general-multi | Deepgram | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| deepgram-nova-3 | Deepgram | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| eleven-flash-v2.5 | ElevenLabs | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| eleven-v3 | ElevenLabs | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| elevenlabs-scribe-v2 | ElevenLabs | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| elevenlabs-scribe-v2-realtime | ElevenLabs | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | Routed to EU | Stays in the region |
| gemini-live-2.5-flash-native-audio | Google Vertex AI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
| gpt-realtime | OpenAI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
| gpt-realtime-2 | OpenAI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
| gpt-realtime-2.1 | OpenAI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
| gpt-realtime-2.1-mini | OpenAI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
| gemini-3.1-flash-lite | Google Vertex AI | N/A | Routed to US | N/A | Stays in the region | Routed to US | N/A | Routed to US | N/A | N/A | Routed to EU | Stays in the region |
| anthropic.claude-haiku-4-5-20251001-v1:0 | Amazon Bedrock | Routed to EU | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| anthropic.claude-sonnet-4-5-20250929-v1:0 | Amazon Bedrock | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to US | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-5.1-2025-11-13 | Azure OpenAI Service | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | N/A | Routed to EU | Routed to EU | Stays in the region |
| anthropic.claude-3-7-sonnet-20250219-v1:0 | Amazon Bedrock | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | N/A | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 |
| gemini-2.5-flash | Google Vertex AI | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to US | Stays in the region | Routed to US | Stays in the region | Routed to EU | Routed to EU | Stays in the region |
| gemini-2.5-flash-lite | Google Vertex AI | N/A | Routed to US | N/A | Stays in the region | Routed to US | N/A | Routed to US | N/A | N/A | Routed to EU | Stays in the region |
| gpt-4.1-mini-2025-04-14 | Azure OpenAI Service | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| anthropic.claude-3-5-sonnet-20241022-v2:0 | Amazon Bedrock | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | N/A | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-4o-mini-2024-07-18 | Azure OpenAI Service | Stays in the region, as gpt-4.1-mini-2025-04-14 | Routed to US, as gpt-4.1-mini-2025-04-14 | Routed to EU, as gpt-4.1-mini-2025-04-14 | Stays in the region, as gpt-4.1-mini-2025-04-14 | Routed to EU, as gpt-4.1-mini-2025-04-14 | Stays in the region, as gpt-4.1-mini-2025-04-14 | Routed to EU, as gpt-4.1-mini-2025-04-14 | Routed to EU, as gpt-4.1-mini-2025-04-14 | Routed to EU, as gpt-4.1-mini-2025-04-14 | Routed to EU, as gpt-4.1-mini-2025-04-14 | Stays in the region, as gpt-4.1-mini-2025-04-14 |
| anthropic.claude-3-5-sonnet-20240620-v1:0 | Amazon Bedrock | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to US, as anthropic.claude-sonnet-4-5-20250929-v1:0 | N/A | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Routed to EU, as anthropic.claude-sonnet-4-5-20250929-v1:0 | Stays in the region, as anthropic.claude-sonnet-4-5-20250929-v1:0 |
| anthropic.claude-3-haiku-20240307-v1:0 | Amazon Bedrock | Routed to EU, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to US, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to EU, as anthropic.claude-haiku-4-5-20251001-v1:0 | Stays in the region, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to US, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to US, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to US, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to EU, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to EU, as anthropic.claude-haiku-4-5-20251001-v1:0 | Routed to EU, as anthropic.claude-haiku-4-5-20251001-v1:0 | Stays in the region, as anthropic.claude-haiku-4-5-20251001-v1:0 |
| gemini-2.0-flash-001 | Google Vertex AI | N/A | Routed to US, as gemini-2.5-flash | N/A | Stays in the region, as gemini-2.5-flash | Routed to US, as gemini-2.5-flash | N/A | Routed to US, as gemini-2.5-flash | N/A | N/A | Routed to EU, as gemini-2.5-flash | Stays in the region, as gemini-2.5-flash |
| text-embedding-ada-002 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | Stays in the region | Stays in the region | Stays in the region |
| Autopilot Search | claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| anthropic.claude-sonnet-4-5-20250929-v1:0 — Upcoming removal: 2027-01-07 — Replacement: claude-sonnet-5-5 | Amazon Bedrock | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.1-2025-11-13 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gemini-2.5-flash | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4o-2024-11-20 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to JA | Routed to EU | Routed to EU | Stays in the region | Stays in the region | |
| Find Obsolete Tests | claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Generate Reports | claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Generate Test Cases | claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Import Test Cases | claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Requirement Evaluation | claude-sonnet-5-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
Cartographer
Coded agents
| Call LLM | claude-opus-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| claude-opus-5-5 | Google Vertex AI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region | |
| claude-sonnet-5-5 | Google Vertex AI | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region | |
| gpt-6-luna | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gpt-6-sol | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gpt-6.1-sol | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| path-mini | UiPath | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.4-2026-03-05 | Azure OpenAI Service | Routed to US | Routed to US | Routed to US | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to US | Routed to US | Routed to EU | Stays in the region | |
| claude-opus-4-5@20251101 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.2-2025-12-11 | Azure OpenAI Service | Routed to US | Routed to US | Routed to US | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | Stays in the region | |
| gpt-4.1-mini-2025-04-14 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Stays in the region | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| text-embedding-3-large | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to US | Stays in the region | Stays in the region | Stays in the region | Stays in the region | |
| text-embedding-ada-002 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to US | Routed to EU | Stays in the region | Stays in the region | Stays in the region |
Context Grounding
| Advanced Ingestion | gemini-3.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-2.5-flash | Google Vertex AI | Stays in the region | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Stays in the region | |
| Batch Transform | gemini-3.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-2.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| Batch Transform with Web Search | gemini-3.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| DeepRAG | gemini-3.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Embeddings | gemini-embedding-001 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
Customer Portal
| gpt-5.1-2025-11-13 | Azure OpenAI Service | Routed to US | Routed to US | N/A | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | N/A | Routed to EU | Stays in the region |
| gemini-3-pro-preview | Google Vertex AI | Routed to GLOBAL, as gemini-3.1-pro-preview | Routed to GLOBAL, as gemini-3.1-pro-preview | N/A | Routed to GLOBAL, as gemini-3.1-pro-preview | Routed to GLOBAL, as gemini-3.1-pro-preview | Routed to GLOBAL, as gemini-3.1-pro-preview | Routed to GLOBAL, as gemini-3.1-pro-preview | N/A | N/A | Routed to GLOBAL, as gemini-3.1-pro-preview | Routed to GLOBAL, as gemini-3.1-pro-preview |
Delegate
Document Understanding
| Generative Activities & Features | gpt-4o-2024-11-20 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Stays in the region |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region | |
| text-embedding-3-large | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Stays in the region | |
| Generative Digitization | gemini-3.7-flash | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region |
| gemini-3.5-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gemini-3.1-flash-lite | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| Generative Extraction & Classification | UiPath Helix 1.0 | UiPath | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
| UiPath Helix 2.0 | UiPath | N/A | N/A | N/A | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region |
UiPath Helix 1.0 and UiPath Helix 2.0, used for generative classification and generative extraction, are UiPath's own proprietary models, not third-party models. They are available only in the EU and US regions, for Document Understanding modern projects, and are not routed to any other region: outside the EU and US, the feature is unavailable rather than routed elsewhere. Neither model is available in ModelHub.
GenAI Activities
| Build, Test & Deploy | claude-opus-5 | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-5.6-sol | Azure OpenAI Service | Routed to US | Routed to US | N/A | Stays in the region | Routed to US | Routed to US | Routed to US | N/A | N/A | Routed to US | Stays in the region | |
| anthropic.claude-opus-4-8 | Amazon Bedrock | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| anthropic.claude-sonnet-4-6 | Amazon Bedrock | Stays in the region | Routed to US | N/A | Stays in the region | Routed to EU | Stays in the region | Routed to EU | N/A | N/A | Routed to EU | Stays in the region | |
| anthropic.claude-opus-4-6-v1 | Amazon Bedrock | Routed to US | Routed to US | N/A | Stays in the region | Routed to EU | Routed to US | Routed to US | N/A | N/A | Routed to EU | Stays in the region | |
| gemini-3.5-flash | Google Vertex AI | Stays in the region | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Stays in the region | |
| gpt-5.5-2026-04-23 | Azure OpenAI Service | Routed to US | Routed to US | N/A | Stays in the region | Routed to US | Routed to US | Routed to US | N/A | N/A | Routed to US | Stays in the region | |
| gpt-5.4-mini-2026-03-17 | Azure OpenAI Service | Routed to US | Routed to US | N/A | Stays in the region | Routed to US | Routed to US | Routed to US | N/A | N/A | Routed to US | Stays in the region | |
| gpt-5.4-2026-03-05 | Azure OpenAI Service | Routed to US | Routed to US | N/A | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | N/A | Routed to US | Stays in the region | |
| claude-opus-4-5@20251101 | Google Vertex AI | Routed to US | Routed to US | N/A | Stays in the region | Routed to EU | Routed to US | Stays in the region | Routed to EU | N/A | Routed to EU | Stays in the region | |
| anthropic.claude-haiku-4-5-20251001-v1:0 | Amazon Bedrock | Routed to US | Routed to US | N/A | Stays in the region | Routed to US | Routed to US | Routed to US | Routed to EU | N/A | Routed to US | Stays in the region | |
| anthropic.claude-sonnet-4-5-20250929-v1:0 | Amazon Bedrock | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to US | Stays in the region | Routed to US | Routed to EU | Routed to EU | Routed to US | Stays in the region | |
| gpt-5.2-2025-12-11 | Azure OpenAI Service | Routed to US | Routed to US | N/A | Routed to US | Routed to US | Routed to US | Routed to US | Routed to US | N/A | Routed to US | Stays in the region | |
| gpt-5-nano-2025-08-07 | Azure OpenAI Service | N/A | N/A | Routed to EU | Stays in the region | N/A | N/A | N/A | N/A | Routed to EU | N/A | Stays in the region | |
| gemini-2.5-pro | Google Vertex AI | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4o-2024-11-20 | Azure OpenAI Service | Routed to EU, as gpt-5.1-2025-11-13 | Stays in the region | Stays in the region, as gpt-5.1-2025-11-13 | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | Routed to EU, as gpt-5.1-2025-11-13 | Stays in the region | Stays in the region | |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Routed to EU, as gpt-5.1-2025-11-13 | Routed to EU | Routed to EU, as gpt-5.1-2025-11-13 | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU, as gpt-5.1-2025-11-13 | Routed to EU | Stays in the region | |
| gpt-4o-mini-2024-07-18 | Azure OpenAI Service | Stays in the region, as gpt-35-turbo-0125 | Stays in the region, as gpt-35-turbo-0125 | Routed to EU, as gpt-5.1-2025-11-13 | Stays in the region | Stays in the region, as gpt-35-turbo-0125 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | N/A | Routed to EU, as gpt-5.1-2025-11-13 | Stays in the region, as gpt-35-turbo-0125 | Stays in the region |
Healing Agent
| Workflow Recovery | path-mini | UiPath | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-2.5-flash | Google Vertex AI | Stays in the region | Routed to US | Routed to EU | Stays in the region | Routed to JA | Stays in the region | Routed to JA | Stays in the region | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | N/A | Routed to EU | Routed to EU | Stays in the region |
IXP
| Feature | Model | AU | CA | CH | EU | IN | JA | SI | SK | UAE | UK | US |
| Extraction model | gpt-5.4-2026-03-05 | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gemini-3.5-flash | Routed to GLOBAL | Routed to GLOBAL | Routed to EU | Stays in the region | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to EU | Routed to EU | Routed to GLOBAL | Stays in the region | |
| gemini-3.5-flash-lite | Routed to GLOBAL | Routed to GLOBAL | Routed to EU | Stays in the region | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to EU | Routed to EU | Routed to GLOBAL | Stays in the region | |
| gemini-3.1-pro-preview | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | N/A | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | |
| gemini-3.1-flash-lite | Routed to GLOBAL | Routed to GLOBAL | Routed to EU | Stays in the region | Routed to GLOBAL | Routed to GLOBAL | Routed to GLOBAL | Routed to EU | Routed to EU | Routed to GLOBAL | Stays in the region | |
| gpt-5.1-2025-11-13 | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gemini-2.5-pro | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gemini-2.5-flash | Stays in the region | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Stays in the region | |
| gpt-4o-2024-08-06 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | N/A | Routed to EU | Routed to EU | Stays in the region | |
| Table model pre-processing | gemini-2.5-flash | Stays in the region | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Stays in the region |
| Model-based attribution | gemini-2.5-flash | Stays in the region | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Stays in the region |
| Autopilot for taxonomy generation | gemini-2.5-flash | Stays in the region | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Stays in the region |
| Generative Extraction & Classification | gpt-4o-2024-08-06 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-5.4-mini-2026-03-17 | N/A | N/A | Routed to EU | Stays in the region | N/A | N/A | N/A | N/A | N/A | N/A | Stays in the region | |
| Generative Annotation | gpt-4o-mini-2024-07-18 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | N/A | Routed to EU | Routed to EU | Stays in the region |
| Suggested labels from clusters | gpt-4o-2024-08-06 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Zero-shot taxonomy generation (Preview) | gpt-4o-2024-08-06 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Conversational filters (Preview) | gpt-4o-2024-08-06 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| Communications Mining summarization | gpt-4o-2024-08-06 | Stays in the region, as gpt-4o-2024-11-20 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
Marketplace
| gpt-4o-mini-2024-07-18 | Azure OpenAI Service | Stays in the region, as gpt-35-turbo-0125 | Stays in the region, as gpt-35-turbo-0125 | Routed to EU | Stays in the region | Stays in the region, as gpt-35-turbo-0125 | N/A | Routed to EU | N/A | Routed to EU | Stays in the region, as gpt-35-turbo-0125 | Stays in the region |
Process Mining
| gpt-4.1-mini-2025-04-14 | Azure OpenAI Service | Stays in the region | Routed to EU | N/A | Stays in the region | Stays in the region | Stays in the region | Routed to EU | Routed to EU | N/A | Routed to EU | Stays in the region |
| gpt-4o-2024-11-20 | Azure OpenAI Service | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Stays in the region | Routed to EU | N/A | Routed to EU | Stays in the region | Stays in the region |
| gpt-4o-mini-2024-07-18 | Azure OpenAI Service | Stays in the region, as gpt-35-turbo-0125 | Stays in the region, as gpt-35-turbo-0125 | Routed to EU | Stays in the region | Stays in the region, as gpt-35-turbo-0125 | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | N/A | Routed to EU | Stays in the region, as gpt-35-turbo-0125 | Stays in the region |
UI Automation
| ScreenPlay | gemini-3.8-flash | Google Vertex AI | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-5.6-sol | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.6-terra | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.6-luna | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.5-2026-04-23 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.4-mini-2026-03-17 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5.4-2026-03-05 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| anthropic.claude-sonnet-4-5-20250929-v1:0 | Amazon Bedrock | Routed to US | Routed to US | N/A | Stays in the region | Routed to US | Routed to US | Routed to US | N/A | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5-2025-08-07 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-5-mini-2025-08-07 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| computer-use-preview-2025-03-11 | Azure OpenAI Service | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Routed to EU | |
| gpt-4.1-2025-04-14 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4.1-mini-2025-04-14 | Azure OpenAI Service | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Routed to US | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| Semantic Activities | path-mini | UiPath | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
| gpt-4o-2024-08-06 | Azure OpenAI Service | Routed to EU | Routed to EU | Routed to EU | Stays in the region | Routed to EU | Stays in the region, as gpt-4o-2024-11-20 | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region | |
| gpt-4o-mini-2024-07-18 | Azure OpenAI Service | Stays in the region, as gpt-35-turbo-0125 | Stays in the region, as gpt-35-turbo-0125 | Routed to EU | Stays in the region | Stays in the region, as gpt-35-turbo-0125 | Routed to US | Routed to EU | Routed to EU | Routed to EU | Stays in the region, as gpt-35-turbo-0125 | Stays in the region | |
| Semantic Selectors | path-mini | UiPath | Routed to US | Routed to US | Routed to EU | Stays in the region | Routed to EU | Stays in the region | Routed to EU | Routed to EU | Routed to EU | Routed to EU | Stays in the region |
Task Mining
1 Available in UiPath as a public preview.
For general information on Data residency, refer to Data residency.
- How data is processed
- AI features residency
- AI residency example
- Models consumed by Autopilot
- Model routings by service
- Legend
- Agents
- Apps
- Autopilot
- Autopilot Actions
- Autopilot for Everyone
- Autopilot actions in Test Manager
- Cartographer
- Coded agents
- Context Grounding
- Customer Portal
- Delegate
- Document Understanding
- GenAI Activities
- Healing Agent
- IXP
- Marketplace
- Process Mining
- UI Automation
- Task Mining
