- Introduction
- Getting started
- Managing solution projects and packages
- Managing solution deployments
- Best practices
Upgrading or downgrading a solution
Upgrade or downgrade a solution deployment to a different package version in Automation Suite.
The Upgrade / Downgrade option allows you to perform the following changes:
- Upgrade your solution to a newer version;
- Downgrade your solution to an older version (similar to a rollback to an older version). Downgrading a solution does not delete entities, choice sets, and webhooks.
To upgrade a solution, take the following steps:
Update your solution package with the changes you want to include in the new version. For details, refer to Editing a solution package version.
Note:If a component of the same name already exists in the tenant, your options are the following:
- Keep the existing component and do not create an additional one.
- Keep the existing component and add additional new fields from the solution. Note that this option does not alter existing fields.
- Rename the conflicting resource in the respective service (for instance, Orchestrator, Action Center) in the target tenant.
- Rename the resource in the solution deployment if possible.
Select the Solutions tab at tenant level.
In the Deployments tab, select the More actions (⋮) menu corresponding to the targeted package, then choose Upgrade / Downgrade.
In the Upgrade / Downgrade window, indicate the package version you want to upgrade or downgrade your solution to, then select Continue. A new screen opens, providing a summary of the changes introduced by the upgrade operation. The following details are provided on the changes the new version introduces:
Newly added components: marked with a plus (+) icon.
Note:These components will be created in the target environment after the upgrade, so make sure to review their properties.
Removed components: marked with a minus (-) icon.
Note:These components will be removed from the target environment after the solution upgrade unless they are referenced by other solutions. In this case, the components will remain within the environment but will be removed from the solution.
Edited components: marked with an asterisk (*) icon. The Compare property differences panel highlights all the changes to the component properties.
Note:Components that only have alterations to their configurable properties are not marked as edited. Edited components retain the existing configurations for their configurable properties by default, but you can switch to using the package configuration. In both cases, if needed, you can update the configurable properties in place. To get an overview of all property changes, check the Compare property differences panel.
Optionally edit any configurable component properties you want.
Save your changes as a draft, validate them, and/or deploy them. After performing an upgrade, you can check the operation status in the Deployments tab. For details, refer to Checking the deployment status.
Note:The status of a newly upgraded solution is
Inactive. Make sure to manually activate the deployment to make the solution functional.
Triggers are always disabled during a solution upgrade. After you re-activate the deployment through Solutions, triggers are restored to their pre-upgrade state — but only if the deployment was previously activated through Solutions.
If triggers were manually enabled directly in Orchestrator (outside of Solutions), those states are not preserved and triggers remain disabled after the upgrade. To ensure trigger states are correctly restored after future upgrades, always activate deployments through Solutions.
