solutions-management
- Introduction
- Getting started
- Managing solution projects and packages
- Managing solution deployments
Solutions user guide
You can remove a solution deployment from a tenant by uninstalling it in an automated manner. The uninstall operation removes from the system the solution folders and all the resources included in it that were created as part of the deployment. However, uninstalling a solution does not delete entities, choice sets, and webhooks. Note that you cannot undo the uninstall operation.
To uninstall a solution, take the following steps:
- Select the Solutions tab at tenant level.
- In the Deployments tab, find the solution you want to uninstall, select the More actions (⋮) menu corresponding to it, then choose Uninstall.
- Type the name of the solution deployment in the newly open window to confirm the action, then select Uninstall.
