solutions-management
Solutions user guide
  • Introduction
  • Getting started
  • Managing solution projects and packages
    • Manage a solution project in Orchestrator
    • Manage a solution package in Orchestrator
    • Navigating the Package sidebar
  • Managing solution deployments
  • Best practices
Download, upload, and manage solution packages in Orchestrator to transport solutions between environments in Automation Suite.
You can transport solutions from an environment to another by downloading and uploading solution packages.
Transport a solution package​
Download a solution package​
  1. Select the Solutions tab at tenant level.
  2. Find your solution package and access its corresponding More actions (⋮) menu, then Download latest version. This allows you to download and share an archive containing the solution package with others.
Upload a solution package​
  1. In the Solutions view, select the desired tenant.
  2. Select Upload solution package. Add your files in the newly open panel.
    Important:
    Successful package uploading on a tenant requires that all resources contained in the package match the enabled services for that specific tenant. If any services are disabled, you have to wait for 30 minutes after enabling them before trying to upload the package again.
Check the package status​
To check package statuses, navigate to the Solutions view and select the Packages tab.
The following table describes the possible statuses of your packages:
Package statusDescription
PendingThe package upload is in progress.
FailedThe package upload failed.
ReadyThe package upload was successful and is available for deployment.
ActiveThe package has at least one deployment.
  • Transport a solution package​
  • Download a solution package​
  • Upload a solution package​
  • Check the package status​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
