orchestrator
2022.4
- Getting started
- Best practices
- Tenant
- About the Tenant Context
- Searching for Resources in a Tenant
- Managing Robots
- Connecting Robots to Orchestrator
- Setup Samples
- Storing Robot Credentials in CyberArk
- Setting up Attended Robots
- Setting up Unattended Robots
- Storing Unattended Robot Passwords in Azure Key Vault (read-only)
- Storing Unattended Robot Credentials in HashiCorp Vault (read-only)
- Deleting Disconnected and Unresponsive Unattended Sessions
- Robot Authentication
- Robot Authentication With Client Credentials
- SmartCard Authentication
- Audit
- Resource Catalog Service
- Folders Context
- Automations
- Processes
- Jobs
- Triggers
- Logs
- Monitoring
- Queues
- Assets
- About Assets
- Managing Assets in Orchestrator
- Managing Assets in Studio
- Storing Assets in Azure Key Vault (read-only)
- Storing Assets in HashiCorp Vault (read-only)
- Storage Buckets
- Orchestrator testing
- Integrations
- Classic Robots
- Troubleshooting
OUT OF SUPPORT
Orchestrator user guide
Last updated Dec 16, 2025
Note: Before performing the following procedure, make sure you have configured your HashiCorp Vault (read-only) integration.
When storing an asset of type
Credential in a read-only credential store, you must create the secret in Vault and make sure you meet the following requirements:
- the path of the secret must contain the data path configured for the credential store, concatenated with the External Name
configured for that value (if using values per robot) or the asset name otherwise. For example, if the data path is
applications/orchestrator/assets, and the External Name isSAPCredentials, then the secret's path must beapplications/orchestrator/assets/SAPCredentials. -
inside the secret, you must have:
- a key named
Username, with the value containing the username of the credentials. - a key named
Password, with the value containing the password of the credentials.
- a key named
Important: The
Username and
Password fields are case sensitive.
