orchestrator
You have been redirected to the first page of the Orchestrator - Automation Suite documentation for the 2022.10 version.
Orchestrator API guide
Last updated Feb 13, 2025
About OData and references
The Orchestrator API implementation is based on the OData protocol. OData (Open Data Protocol) is an ISO/IEC approved OASIS standard that defines a set of best practices for building and consuming RESTful APIs.
The Open Data Protocol (OData) enables the creation of REST-based data services, which allow resources, identified using URLs and defined in a data model, to be published and edited by Web clients using simple HTTP messages. This specification defines the core semantics and the behavioral aspects of the protocol.
The default format for the Orchestrator OData metadata endpoint is JSON, and the metadata URL is https://{yourDomain}/odata. To change the default format to XML, append /?$format=xml to this URL.
For more information on protocol principles and definitions, we recommend checking the official OData official documentation.
Note: We aim at compliance with the OData standard, but cannot guarantee it. While the standard mandates that the metadata endpoint should return XML format by default, we return JSON for historical compatibility.
Logical resources and metadata
The Orchestrator API provides custom methods for querying stats about various entities registered in Orchestrator. Each logical resource is an OData entity. All entities (such as Robot, Process, Queue) have properties, relationships, and operations.
Available operations
CRUD operations
These types of operations are available on logical resources most. CRUD operations include GET, POST, PUT and DELETE requests, but please note that not all logical resources make use of all these verbs due to both technical and business reasons.
Requesting data
It is possible to request particular information from a particular resource, in conjunction with GET operations, through OData-specific parameters.
They enable you to query, filter, sort, select and expand information. More details can be found in the official OData documentation.
Custom actions
The following custom actions and actions which are not tied to a logical resource are available in the Orchestrator API:
  • Stats methods provide aggregates information on different entities;
  • Account methods provide authentication methods to Orchestrator;
  • Queues methods are used by the Robot to access queues, while the QueueDefinitions endpoint should be used instead for external systems via API;
  • QueueProcessingRecords methods offer statistical and aggregate information about queues;
  • RobotsService resources can be used by Orchestrator to communicate with the Robot.
