studio-web
Notes de publication de Studio Web
  • Automation Cloud et Test Cloud
    • 2026
      • Octobre 2026
      • Septembre 2026
      • Août 2026
      • Juillet 2026
      • Juin 2026
      • Mai 2026
      • Avril 2026
      • Mars 2026
      • Février 2026
  • Automation Cloud dédié et Test Cloud dédié
Octobre 2026
October 2026 release notes for Studio Web in Automation Cloud.
October 1, 2026​
Paste key-value pairs into dictionary properties​
You can now populate a dictionary property in API workflow activities, such as the Query parameters field in the HTTP request activity, by pasting multiple key-value pairs at once instead of adding each entry manually. You can also switch the Dictionary editor to a text view to edit all entries together.
Améliorations​
  • You can now press the Esc key to close the Expression editor without saving your changes, the same as selecting Cancel.
  • Debug sessions now start faster in solutions that contain apps not used as action apps, because Studio Web no longer publishes these apps before debugging.
Résolution de bogues​
  • Opening a local solution connected to a Git repository could rewrite parts of a workflow file even when you hadn't made any changes, creating unnecessary version-control differences. Workflow files are no longer modified unless their content actually changes.
  • Opening and saving a workflow generated by Autopilot reformatted the entire file because Autopilot-generated workflows did not use the same formatting as the Studio Web designer.
  • Publishing an API workflow created before a required configuration file was introduced could fail with a "Corrupted solution package" error. Opening the project now regenerates the missing file automatically.
  • Bullet and numbered lists in rich text fields, such as the Rich Text Editor, did not render their markers as expected. The list text saved correctly but displayed as a plain paragraph.
  • October 1, 2026​
  • Paste key-value pairs into dictionary properties​
  • Améliorations​
  • Résolution de bogues​
