- Overview
- Quickstart tutorials
- Framework components
- ML packages
- Overview
- Document Understanding - ML package
- DocumentClassifier - ML package
- ML packages with OCR capabilities
- 1040 - ML package
- 4506T - ML package
- 990 - ML Package - Preview
- ACORD125 - ML package
- ACORD126 - ML package
- ACORD131 - ML package
- ACORD140 - ML package
- ACORD25 - ML package
- Bank Statements - ML package
- Bills Of Lading - ML package
- Certificate of Incorporation - ML package
- Certificate of Origin - ML package
- Checks - ML package
- Children Product Certificate - ML package
- CMS 1500 - ML package
- EU Declaration of Conformity - ML package
- Financial Statements - ML package
- FM1003 - ML package
- I9 - ML package
- ID Cards - ML package
- Invoices - ML package
- Invoices Australia - ML package
- Invoices China - ML package
- Invoices India - ML package
- Invoices Japan - ML package
- Invoices Shipping - ML package
- Packing Lists - ML package
- Passports - ML package
- Payslips - ML package
- Purchase Orders - ML package
- Receipts - ML package
- Remittance Advices - ML package
- Utility Bills - ML package
- Vehicle Titles - ML package
- W2 - ML package
- W9 - ML package
- Other Out-of-the-box ML Packages
- Public Endpoints
- Hardware requirements
- Pipelines
- Document Manager
- OCR services
- Deep Learning
- Document Understanding deployed in Automation Suite
- Install and use
- First run experience
- Deploy UiPathDocumentOCR
- Deploy an out-of-the-box ML package
- Offline bundles 2023.4.13+patch1
- Offline bundles 2023.4.12
- Offline bundles 2023.4.11
- Offline bundles 2023.4.10+patch1
- Offline bundles 2023.4.9
- Offline bundles 2023.4.8
- Offline bundles 2023.4.7
- Offline bundles 2023.4.6
- Offline Bundles 2023.4.5
- Oflline bundles 2023.4.4
- Offline Bundles 2023.4.3
- Offline Bundles 2023.4.2
- Offline Bundles 2023.4.1
- Offline Bundles 2023.4.0
- Use Document Manager
- Use the Framework
- Document Understanding deployed in AI Center standalone
- Licensing
- Activities
- UiPath.Abbyy.Activities
- UiPath.OCR.Activities
- UiPath.OCR.Contracts
- UiPath.OmniPage.Activities
- UiPath.PDF.Activities
Create a UiPathDocumentOCR ML package in AI Center.
For online installation, the UiPathDocumentOCR model is already included in the Out of the box packages section.
For offline instalation, follow the steps included in the Upload model to AI Center section.
Go to ML Packages > Out of the box packages > UiPath Document Understanding > UiPathDocumentOCR, and select Submit.
Go to ML Skills and create a new ML skill for the UiPathDocumentOCR package you created.
Please use Advanced Infra Settings to update the deployment to update the replica (the number of replica should ideally be equal to the number of nodes) and maximize the CPU (at least 4) and RAM requests if you are not using GPU machines, or the UiPathDocumentOCR processing will be slow and may fail.
The OCR engine needs GPU for optimal performance, and it is recommended for production workloads. However, if GPU is not available, it can still run on CPU, but it requires higher resources than the default. Advanced infra settings should be adjusted as such:
Replicas: increase if there is concurrent usage of UiPathDocumentOCR. If you are using UiPathDocumentOCR to do imports on a single Data Labeling session at a time and the UiPathDocumentOCR is not used in other UiPath® workflows then 1 replica suffices. Otherwise, the number of replicas needs to be increased. There is no "magic" number here, you need some trial and error. Do not use more than 2 replicas on a single node installation. Ideally, replica count should equal the number of nodes in the cluster (1 replica/node). If more parallelism is needed, increasing the CPU helps
CPU: it should be at least 4 (for each replica). Make sure you have appropriate resources. There is no "magic" number, but more CPU means faster processing time. You need to test under your specific scenarios what is enough.
It can take up to 30 minutes for the ML Skill to be ready. You may need to refresh the AI Center page for the status to change. Once the ML Skill is available, select the ML Skill and go to Modify current deployment.
Switch the toggle on to make the ML Skill public. You may need to wait for a few minutes and refresh the page.
Select the ML Skill and copy the URL, which is the endpoint of the UiPathDocumentOCR for later use.
