document-understanding
Document Understanding User Guide
Last updated Nov 6, 2025
Deploy an out-of-the-box ML package
This page describes how to deploy an out-of-the-box Document UnderstandingTM ML Package. For demonstration purposes, we are going to use the Invoices ML Package as an example.
Create an Invoices ML package
For online installation, the Invoices model is already included in the Out of the box packages section. Go to ML Packages > Out of the box packages > UiPath Document Understanding > Invoices, and select Submit.
For offline installation, please upload the Invoices ML Package as a Zip file. To download the models, contact your Account Manager, CSM, or Support. You will receive a download link per package.
  1. Go to ML Packages > Upload a zip file to start uploading the zip file.
  2. Choose Json input type and the corresponding Python language.
  3. Select Create.
Deploy the Invoices ML package as an ML Skill
  1. Navigate to the ML Skills tab from the left sidebar of AI Center and create a new ML Skill.
    Note: This can take up to 30 minutes.
  2. Once the ML Skill is created, select the ML Skill and go to Modify current deployment.
  3. Switch the toggle on to make the ML Skill public. You may need to wait for a few minutes and refresh the page.
  4. Once the ML Skill is ready, copy the URL, which is the endpoint of the Invoices ML package for later use.
