2023.4.5
Release date: February 28, 2024
Erratum - Added March 25, 2024: We now support Microsoft SQL Server 2022.
Erratum - Added March 18, 2024: We have removed the following URLs from our URL proxy allowlist:
ftp.byfly.by
ftp.gwdg.de
mirror.firstyear.id.au
ftp.lysator.liu.se
mirror-jp.firstyear.id.au
For more details on the proxy configuration, see Proxy.
We have added support for Kubernetes 1.28 and removed support for Kubernetes 1.25. We recommend that you check the Compatibility matrix and make sure you upgrade to a supported version, if needed.
We continue to provide security updates and patches to address Common Vulnerabilities and Exposures (CVEs).
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Erratum: Added April 19, 2024
argocd-redis-ha-server
pod is put in error state. If you encounter this issue, use the workaround documented in the Troubleshooting chapter. The issue no longer occurs in Automation Suite 2023.4.6.
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
This Automation Suite release bundles the following internal components:
Component |
Version |
Istio | 1.20.0 |
ArgoCD | v2.5.10 |
Prometheus | v2.42.0 |
Grafana |
10.2.3 |
Fluentd & Fluent-bit |
logging-operator : 4.2.1 logging-operator-logging : 4.1.1 |
Gatekeeper | 3.11.0 |
Cert-Manager | v1.11.2 |
Velero | 3.1.6 |
