2023.4.4
Release date: December 19, 2023
Erratum - added April 19, 2024: We have fixed an issue causing the Prometheus pods to fail to start due to an out-of-memory (OOM) error.
Erratum - Added March 25, 2024: We have fixed a bug in the data migrator that was affecting the transfer of permission snapshots between two databases.
Red Hat no longer supports RHEL 8.3, 8.4, 8.5, and 8.7. As a result, we have removed them from the list of compatible RHEL versions. We currently support RHEL 8.6 and 8.8, but we recommend using the latter.
If you move from an older Automation Suite version, make sure you use a supported RHEL version before starting the upgrade.
For more details, see the Automation Suite hardware and software requirements.
Erratum - added April 19, 2024: In certain situations, Ceph metrics and alerts are missing from the monitoring dashboards. To fix the issue, see the Troubleshooting section.
Erratum - added February 28, 2024: Stored procedures do not support collation differences between the SQL server and SQL database. To avoid any potential problems, you must ensure that the collation settings of both SQL server and SQL database are identical.
To avoid CVEs related to Flannel and Calico, we recommend taking the following steps:
- Migrate from Canal to Cilium CNI.
- Delete the following Calico and Flannel images:
- image: rancher/hardened-calico, tag: v3.22.2-build20220509
- image: rancher/hardened-flannel, tag: v0.17.0-build20220317
For details, see How to delete images from the old installer after upgrade.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
This Automation Suite release bundles the following internal components:
Component |
Version |
RKE2 |
1.24.8 |
ArgoCD |
2.5.10 |
logging-operator | 4.1.0 |
logging-operator-logging |
4.1.0 |
gatekeeper | 3.11.0 |
rook-ceph |
1.9.4 |
prometheus-pushgateway |
2.1.6 |
cert-manager |
1.11.2 |
rancher-istio | 102.2.0-up1.17.2 |
rancher-logging | 100.1.3-up3.17.7 |
rancher-logging-crd | 100.1.3-up3.17.7 |
rancher-monitoring-crd | 100.0.0-up16.6.0 |
rancher-gatekeeper-crd | 100.2.0-up3.8.1 |
rancher-gatekeeper | 100.2.0-up3.8.1 |
rancher-monitoring | 100.0.0-up16.6.0 |
longhorn |
1.3.1 |
longhorn-crd |
1.1.100 |
reloader |
0.0.129 |
csi-driver-smb |
1.8.0 |
velero |
3.1.6 |
redis-operator |
7.2.4-7 |
redis-cluster |
7.2.4-64 |
- What's new
- Bug fixes
- Out-of-support RHEL versions
- Known issues
- Issues affecting Ceph metrics and alerts
- Issues related to CephMgrIsAbsent alerts
- Collation differences between SQL server and SQL database not supported
- CVEs related to Flannel and Calico
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
