Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2023.4.0
    • 2023.4.1
    • 2023.4.2
    • 2023.4.3
    • 2023.4.4
    • 2023.4.5
    • 2023.4.6
    • 2023.4.7
    • 2023.4.8
    • 2023.4.9
    • 2023.4.11
  • Automation Suite on EKS/AKS Release Notes
    • 2023.4.1
    • 2023.4.2
    • 2023.4.3
    • 2023.4.4
    • 2023.4.5
    • 2023.4.6
    • 2023.4.7
    • 2023.4.8
2023.4.4
Release date: December 19, 2023
What's new​
This release only brings updates to the products bundled in Automation Suite.
Bug fixes​
  • Erratum - added May 20, 2024: Previously, on single-node deployments with in-cluster storage, upgrades from version 2022.4.1 or older would fail at the fabric stage. A rook-ceph migration issue was causing the failure. The behavior no longer occurs.
  • Erratum - added April 19, 2024: We have fixed an issue causing the Prometheus pods to fail to start due to an out-of-memory (OOM) error.
  • Erratum - Added March 25, 2024: We have fixed a bug in the data migrator that was affecting the transfer of permission snapshots between two databases.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Known issues​
Erratum - added October 17, 2024
In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
Erratum - added August 14, 2024
For AI Center and Task Mining, the ListBucket API prerequisite check fails when using an external objectstore. However, AI Center and Task Mining do not use the ListBucket API permission. We removed the unnecessary check in Automation Suite 2023.4.8.
Erratum - added June 25, 2024
Following an Automation Suite on AKS installation or upgrade, the backup setup does not work because of a failure to connect to Azure Government. You can fix the issue by taking the steps described in Automation Suite on EKS/AKS troubleshooting.
Erratum: Added April 19, 2024
An upgrade known issue affecting AKS causes Automation Suite to fail. When trying to upgrade AKS, the argocd-redis-ha-server pod is put in error state. If you encounter this issue, use the workaround documented in the Troubleshooting chapter. The issue no longer occurs in Automation Suite 2023.4.6.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.4.4Automation Ops 2023.4.4AI Center 2023.4.4Action Center 2023.4.4
Task Mining 2023.4.4AI Computer Vision 2023.4.4Insights 2023.4.4Apps 2023.4.4
Process Mining 2023.4.4Document Understanding 2023.4.4Orchestrator 2023.4.4
Test Manager 2023.4.4
Data Service 2023.4.4
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.17.2 (Distroless)
ArgoCDv2.5.10
Prometheusv2.42.0
Grafana10.1.1
Fluentd & Fluent-bitlogging-operator : 4.1.1
logging-operator-logging : 4.1.1
Gatekeeper3.11.0
Cert-Managerv1.11.2
Velero3.1.6
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Stay updated
