Automation Suite API guide
  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Get Specific Group
Returns information about a group, based on the organization and group ID.
API Endpoint
GET https://{yourDomain}/{organizationName}/identity_/api/Group/{partitionGlobalId}/{groupId}
Scopes
Requires the following scopes:
  • PM.Group
  • PM.Group.Read
Request Headers
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
Note: To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters
Path param
Data type
partitionGlobalId
(required)
String
The ID of the organization containing the desired group.
groupID
(required)
String
The ID of the group you want to retrieve.
Responses
200 OK
The specified group information is returned.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/identity_
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: 3fa85f64-5717-4562-b3fc-2c963f66afa6
  • The {groupID} is: 2512
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Group/3fa85f64-5717-4562-b3fc-2c963f66afa6/2512' \
--header 'Content-Type: application/json'curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Group/3fa85f64-5717-4562-b3fc-2c963f66afa6/2512' \
Here's the response body for a successful call:
    "id": "2512",
    "name": "Automation Developers",
    "displayName": "Automation Developers",
    "type": 0,
    "creationTime": "2021-10-19T14:25:01.6574988",
    "lastModificationTime": "2021-10-19T14:25:01.6574988",
    "members": [
            "objectType": "DirectoryUser",
            "firstName": "Albus",
            "lastName": "D",
            "jobTitle": "master",
            "companyName": "Hogwarts",
            "city": "London",
            "department": "magic",
            "displayName": "Albus D",
            "source": "local",
            "identifier": "1787ef38-5933-4f2c-a67a-9c22cdb8e6a2",
            "name": "albus",
            "email": "albus@hogwarts.com"
    "id": "2512",
    "type": 0,
    "members": [
            "lastName": "D",
            "city": "London",
            "source": "local",
            "name": "albus",
  • API Endpoint
  • Scopes
  • Request Headers
  • Path Parameters
  • Responses
  • 200 OK
  • Example Request
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
