  • Release Notes
    • 2022.10.0
    • 2022.10.1
    • 2022.10.2
    • 2022.10.3
    • 2022.10.4
    • 2022.10.5
    • 2022.10.6
    • 2022.10.7
    • 2022.10.8
    • 2022.10.9
    • 2022.10.10
    • 2022.10.11
    • 2022.10.12
    • 2022.10.13
      • 2022.10.14+patch1
      • 2022.10.14+patch2
    • 2022.10.15
Automation Suite release notes
Last updated Nov 6, 2025
2022.10.14+patch2
Release date: June 30, 2025
About this patch
This release applies a patch to Automation Suite 2022.10.14. The patch addresses some issues in Orchestrator. For more details, see the individual product release notes referenced in the Product versions section.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2022.10.14Automation Ops 2022.10.13AI Center 2022.10.14Action Center 2022.10.12
Task Mining 2022.10.14AI Computer Vision 2022.10.14Insights 2022.10.12Apps 2022.10.14
Process Mining 2022.10.14Document Understanding 2022.10.14Orchestrator 2022.10.17
  Test Manager 2022.10.11
  Data Service 2022.10.14
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.30.5
ArgoCD2.11.3
rook-ceph1.14.6
cert-manager1.14.5
rancher2.9.0
rancher-gatekeeper103.1.0-up3.13.0
rancher-istio104.4.0-up1.22.1
rancher-monitoring-crd104.1.0-up57.0.3
rancher-monitoring104.1.0-up57.0.3
longhorn1.6.2
longhorn-crd1.1.100
reloader1.0.95
csi-driver-smb1.16.0
rabbitmq-operator2.2.0
redis-operator7.4.6-2
redis-cluster7.4.6-22
mongodb5.0.7-ent
docker_registry2.8.3
  • About this patch
  • How to apply the patch
  • Deprecation timeline
  • Bundling details
  • Product versions
  • Internal third-party component versions
