Automation Hub API Guide
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
| Key | Value | Use Case |
| submissionType | Employee-driven Idea = 1 | Filter |
| CoE-driven Idea = 2 | Filter | |
| Citizen Development Driven Idea = 3 | Filter | |
| Process Mining Idea = 4 | Filter |
- By default, GET Automations and GET Automation Pipeline will return only Employee Driven and CoE Driven ideas (even if the submissionType parameter is not used). To get Citizen Development or Process Mining ideas, the submissionType parameter must be specifically added in the query.
Example: submissionType=1
UI Correspondent:
- Submitting an Employee-driven Idea
- Submitting a CoE-driven Idea
