Automation Hub API guide
Input for Phase
Phase input values for Automation Hub API calls in Automation Suite 2.2510, with a note that phase keys must not be used in POST status update calls.
Note:
For the POST call made to update an idea phase and status do not use the phase or status keys.
KeyPhase namePhase ID
IDEAIdea1
ASSESSMENTAssessment2
QUALIFICATIONQualification3
ANALYSISAnalysis4
SOLUTION_DESIGNSolution Design5
DEVELOPMENTDevelopment6
TESTINGTesting7
HYPERCAREHypercare8
LIVELive9
BUSINESS_REVIEWBusiness Review10
TECHNICAL_REVIEWTechnical Review11
Example: phase=2
UI Correspondent​
  • Automation Phase and Status
  • UI Correspondent​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
