apps
Legacy Apps User Guide for Automation Suite
Use Master Detail View
Overview​
You can use the Master Detail View to reference information from the row of a table or a custom list. By doing so, you can achieve the following:
  • Select and reference one item from a drop-down.
  • Select an item from a list or table and reference columns from that record.
  • Bind the selected record data within an expression. Changes to the selected item are reflected on expression-bound controls.
Using the Master Detail View in a Table​
To reference the information from a selected row in a table bound to Orchestrator output, follow the procedure below.
  1. Open your already existing application or start a new one.
  2. Add a button control and use it to start the process.
  3. Create a table with a column called Name.
  4. Bound the table column to an Orchestrator output by selecting it in the Data Source property. In this example we will pick a source called Out.out_datatable.
  5. Create a label and pick Name from the Table.SelectedValue category from the Resources in the Text property.
  6. Save the app and preview it.
  7. Press the button to initiate the process.
  8. Once the table is displayed, select any row from the table. The information from the Name column should now be displayed in the label configured at Step 5.
  • Overview​
  • Using the Master Detail View in a Table​
Connect
Stay updated
