- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
configureUiPathDisks.sh
script. For details, see the following sections.
Before the installation, you must partition and configure the disk using LVM, so that its size can be altered easily and without any data migration or data loss.
Disk partitioning
/var
partition. By default, the var
partition is allocated only 8 GiB of space.
- The supported format for disk is
ext4
orxfs
. - All partitions must be created using LVM. This is to ensure that cluster data can reside on a different disk, but still be able to be viewed coherently. This also helps in extending the partition size in the future without the risk of data migration or data loss.
- All the pods and application logs are stored under the
/var/log/pods
directory. Make sure that the capacity of this directory is at least 8 GiB. We also recommend configuringlogrotate
to rotate the logs at an interval ranging from daily to weekly.
For the RHEL OS, you need to ensure you have the following minimum mount point sizes on the machine.
Online
Disk label |
Partition |
Size |
Purpose |
Cluster disk |
190 GiB |
Rancher folder stores container images and layers |
56 GiB |
Kubelet folder stores runtime Kubernetes configurations such as secrets, configmaps, and emptyDir | |
10 GiB |
Installer binary | |
etcd disk |
16 GiB |
Distributed database for Kubernetes |
Block storage |
512 GiB |
Block storage abstraction |
Objectstore1 |
N/A |
512 GiB | In-cluster objectstore |
We recommend that you do not use OS disk for any of the above purposes, to ensure processes get their fair share of resources.
Offline
The requirements for offline are the same as online, except for the first machine where you run the install on, which needs the following requirements.
The extra space is needed to unpack the offline bundle.
Disk label |
Partition |
Size |
Purpose |
Cluster disk |
190 GiB |
56 GiB |
10 GiB |
etcd disk |
16 GiB |
Block storage |
512 GiB |
Objectstore1 |
N/A | 512 GiB |
UiPath bundle disk |
512 GiB |
Air-gapped bundle |
Data and etcd disks should be separate physical disks. This physically isolates the data and etcd disk from other cluster workload and activity while also enhancing the performance and stability of the cluster.
See the following section for details on how to use the sample script to partition and configure the disk before installation.
Downloading the script
script to configure and partition the disk.
For download instructions, see configureUiPathDisks.sh.
Running the script
script for the following purposes:
- configure the disks and mount points for a new Automation Suite cluster installation;
- resize the data disk post-installation.
To make the script executable, run:
chmod +x ./configureUiPathDisks.sh
For more details on the script usage, run:
sudo ./configureUiPathDisks.sh --help
Utility to configure the disk for UiPath Automation Suite Installation.
Run this script to configure the disks on new machine or to extend the size of datadisk
Arguments
-n|--node-type NodeType, Possible values: agent, server. Default to server.
-i|--install-type Installation mode, Possible values: online, offline. Default to online.
-c|--cluster-disk-name Device to host rancher and kubelet. Ex: /dev/sdb.
-e|--etcd-disk-name Device to host etcd, Not required for agent node. Ex: /dev/sdb.
-R|--ceph-raw-disk-name Device to host ceph OSD, Not required for agent node. Ex: /dev/sdm
-l|--data-disk-name Device to host datadisk, Not required for agent node. Ex: /dev/sdc.
-b|--bundle-disk-name Device to host the uipath bundle.
Only required for offline installation on 1st server node.
-k|--robot-package-disk-name Device to host robot package cache folder
Only required for Automation Suite Robots dedicated node when 'packagecaching' is enabled
-P|--robot-package-path Path to robot package cache folder
(defaults to '/uipath_asrobots_package_cache' if not set)
-f|--complete-suite Installing complete product suite or any of these products:
aicenter, apps, taskmining, documentunderstanding.
This will configure the datadisk volume to be 2TiB instead of 512Gi.
-p|--primary-server Is this machine is first server machine? Applicable only for airgap install.
This is the machine on which UiPath AutomationSuite bundle will be installed.
Default to false.
-x|--extend-data-disk Extend the datadisk. Either attach new disk or resize the exiting datadisk.
-r|--resize Used in conjunction of with --extend-data-disk to resize the exiting volume,
instead of adding new volume.
-d|--debug Run in debug.
-h|--help Display help.
ExampleUsage:
configureUiPathDisks.sh --node-type server --install-type online \
--cluster-disk-name /dev/sdb --etcd-disk-name /dev/sdc \
--data-disk-name /dev/sdd
configureUiPathDisks.sh --data-disk-name /dev/sdh \
--extend-data-disk
Arguments
Default to false.
ExampleUsage:
--extend-data-disk
Online
To configure the disk in an online single-node evaluation setup, run the following command on the machine:
./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk \
--etcd-disk-name name_of_etcd_disk \
--data-disk-name name_of_data_disk
Offline
In an offline installation, you must load the product’s images in the docker registry. For that, additional storage in the form of a separate disk is required to host the UiPath product bundle.
To configure the disk in an offline single-node evaluation setup, run the following command on the machine:
--data-disk-name name_of_data_disk \
--bundle-disk-name name_of_uipath_bundle_disk \
--primary-server \
--install-type offline
--primary-server \
You can expand your storage size for the in-cluster objectstore by running the following script:
./configureUiPathDisks.sh --ceph-raw-disk-name name_ceph_raw_disk
To increase the size of your in-cluster storage post-installation, rerun the same command.
To extend the data disk, you can attach the new physical disk or resize the existing disk.
Adding a new disk
To extend the data disk using the newly attached disk, run the following command on the server machine:
./configureUiPathDisks.sh --data-disk-name name_of_data_disk \
--extend-data-disk
--extend-data-disk
Resizing the existing disk
To extend the data disk by resizing an existing disk, run the following command on the server machine:
./configureUiPathDisks.sh --extend-data-disk --resize
The following page helps Linux administrators on managing OS and kernel level settings before performing an Automation Suite installation.
Usually, these settings are managed via a dedicated management configuration tool, such as Puppet. Make sure that the changes you make are according to the control process of your environment for consistency and documentation purposes.
Make sure to complete the following steps before starting the installation, as misconfigurations at the OS and kernel level can lead to non-intuitive errors. Checking these specific settings can often avoid such errors.
sysctl
settings are required on the machine:
enable IP forwarding
disable reverse path filtering
You can do this by running the following command:
cat <<EOF >>"/etc/sysctl.d/99-sysctl.conf"
net.bridge.bridge-nf-call-iptables = 1
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-ip6tables = 1
net.ipv4.conf.all.rp_filter=0
EOF
EOF
nf-call-iptables
is needed for most Kubernetes deployments. Kubernetes creates virtual networks internal to the cluster. This allows every
pod to have its own IP address, which is used in conjunction with the internal name services to facilitate service-to-service
communication. The cluster does not work without nf-call-iptables
enabled. For details, see the official Kubernetes documentation.
To apply the settings, run the following command:
sysctl --system
sysctl --system
If using fapolicy, an RKE2 specific policy is required. To generate this, use the following command:
cat <<-EOF >>"/etc/fapolicyd/rules.d/69-rke2.rules"
allow perm=any all : dir=/var/lib/rancher/
allow perm=any all : dir=/opt/cni/
allow perm=any all : dir=/run/k3s/
allow perm=any all : dir=/var/lib/kubelet/
EOF
EOF
Ensure that the change is communicated to your Linux team and goes through the appropriate configuration management processes.
/var/lib/rancher
mount must not have noexec
or nosuid
set. The disk tool automatically creates these mounts without these properties.
If a Linux administrator manually sets these properties, the instance becomes non-functional.
For more details on disk configuration, see Disk requirements.
Make sure that you have the following ports enabled on your firewall for each source.
Port |
Protocol |
Source |
Purpose |
Requirements |
TCP |
Jump Server / client machine |
For SSH (installation, cluster management debugging) |
Do not open this port to the internet. Allow access to client machine or jump server. |
TCP |
Offline installation only: required for sending system email notifications. | ||
TCP |
All nodes in a cluster + load balancer |
For HTTPS (accessing Automation Suite) |
This port should have inbound and outbound connectivity from all the nodes in the cluster and the load balancer. |
TCP |
TCP |
All nodes in the cluster |
Used by Cilium for monitoring and handling pod crashes. |
This port should have inbound and outbound connectivity from all the nodes in the cluster. |
If you enabled Task Mining and provisioned a dedicated Task Mining node and/or provisioned a dedicated node with GPU support, make sure that in addition to the above you have the following ports enabled on your firewall:
Port |
Protocol |
Source |
Purpose |
Requirements |
TCP |
All nodes in a cluster |
etcd client port |
Must not expose to the internet. Access between nodes should be enough over a private IP address. |
TCP |
etcd peer port |
TCP |
For accessing Kube API using HTTPS, and required for node joining |
This port should have inbound and outbound connectivity from all nodes in the cluster. |
UDP |
Required for Flannel (VXLAN) |
TCP |
For accessing Kube API using HTTPS, required for node joining |
This port should have inbound and outbound connectivity from all nodes in the cluster and the load balancer. |
TCP |
kubelet / metrics server |
TCP |
NodePort port for internal communication between nodes in a cluster |
6443
outside the cluster boundary is mandatory if there is a direct connection to the Kerberos API.
9345
is used by nodes to discover existing nodes and join the cluster in the multi-node deployment. To keep the high availability
discovery mechanisms running, we recommend exposing it via the load balancer with health check.
Also ensure you have connectivity from all nodes to the SQL server.
Do not expose the SQL server on one of the Istio reserved ports, as it may lead to connection failures.
If you have a firewall setup on the network, make sure that it has these ports open and allows traffic according to the requirements mentioned above.
To install and validate the required RPM packages, you can use any of the following tools
- the install-uipath.sh manual installer. In online environments, it installs and validates all RPM packages by default.
- the
installUiPathAS.sh
interactive installer. It validates all RPM packages via theinstall-uipath.sh
installer. -
- to validate the RPM packages, run:
validateUiPathASReadiness.sh validate-packages
; - to install the RPM packages in an online installation, run:
validateUiPathASReadiness.sh install-packages
; - to install the RPM packages in an offline installation, run:
validateUiPathASReadiness.sh install-packages --install-type offline
For a list of RPM package requirements, see Hardware and software requirements.
This section explains how to enable FIPS 140-2 on your machines.
You can enable FIPS on your Red Hat Linux-based virtual machines. To do that, take the following steps:
Enable FIPS by running the following command on all your machines before starting the installation:
fips-mode-setup --enable
fips-mode-setup --enable -
Reboot your machines and check if you successfully enabled FIPS by running the following command:
fips-mode-setup --check
For details on the additional steps you must take to start using Automation Suite on FIPS 140-2 machines, see Security best practices.
To configure a proxy, you need to perform additional configuration steps while setting up your environment with the prerequisites and during the advanced configuration phase of installation time.
The following steps are required when setting up your environment.
We currently do not support HTTPS proxy with self-signed certificates. Make sure you use a public trusted certificate if you are configuring the proxy.
Make sure that you have the following rules enabled on your network security group for the given Virtual Network.
Source |
Destination |
Route via proxy |
Port |
Description |
Virtual Network |
SQL |
No |
SQL server port |
Required for SQL Server. |
Virtual Network |
Load Balancer |
No |
Required to add new nodes to the cluster. |
Virtual Network |
Cluster(subnet) |
No |
All ports |
Required for communication over a private IP range. |
Virtual Network |
No |
Required for login and using ArgoCD client during deployment. |
Virtual Network |
Proxy Server |
Yes |
All ports |
Required to route traffic to the proxy server. |
Virtual Network |
NameServer |
No |
All ports |
Most of the cloud services such as Azure and AWS use this to fetch the VM metadata and consider this a private IP. |
Virtual Network |
MetaDataServer |
No |
All ports |
Most of the cloud services such as Azure and AWS use the IP address
169.254.169.254 to fetch machine metadata.
When configuring the nodes, you need to add the proxy configuration to each node that is part of the cluster. This step is required to route outbound traffic from the node via the proxy server.
Add the following configuration in
/etc/environment
:http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT> https_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT> no_proxy=alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>,<private_subnet_ip>,localhost,<Comma separated list of ips that should not got though proxy server>
http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT> https_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT> no_proxy=alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>,<private_subnet_ip>,localhost,<Comma separated list of ips that should not got though proxy server> -
/etc/wgetrc
http_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT> https_proxy=http://<PROXY-SERVER-IP>:<PROXY-PORT> no_proxy=alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>,<private_subnet_ip>,localhost,<Comma separated list of ips that should not got though proxy server>Mandatory parameters
http_proxy
Used to route HTTP outbound requests from the node. This should be the proxy server FQDN and port.
https_proxy
Used to route HTTPS outbound requests from the node. This should be the proxy server FQDN and port.
no_proxy
Comma-separated list of hosts, IP addresses that you do not want to route via the proxy server. This should be a private subnet, SQL server host, named server address, metadata server address:alm.<fqdn>,<fixed_rke2_address>,<named server address>,<metadata server address>
– Most of the cloud services such as Azure and AWS use this to resolve DNS query.metadata server address
– Most of the cloud services such as Azure and AWS use the IP address169.254.169.254
Important:If you use AI Center with an external Orchestrator, you must add the external Orchestrator domain to theno_proxy
list. -
Verify if the proxy settings are properly configured by running the following command:
curl -v $HTTP_PROXY curl -v <fixed_rke_address>:9345
curl -v $HTTP_PROXY curl -v <fixed_rke_address>:9345Important: Once you meet the proxy server requirements, make sure to continue with the proxy configuration during installation. Follow the steps in Optional: Configuring the proxy server to ensure the proxy server is set up properly.
- Configuring the disk
- Disk requirements
- Using the script to configure the disk
- Configuring the disk for a single-node evaluation setup
- Configuring the Objectstore disk
- Extending the data disk post-installation
- Validating disk mounts
- Configuring kernel and OS level settings
- Configuring sysctl settings
- Configuring fapolicy settings
- Configuring noexec and nosuid settings
- Enabling ports
- Installing the required RPM packages
- Enabling FIPS 140-2
- Step 1: Enabling ports on the virtual network
- Step 2: Adding proxy configuration to each node
