- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite can currently connect only with a Docker registry that is signed by a public certificate (for example, a public certificate provided by cloud providers such as ACR, ECR, etc.). We are still working on providing support for Docker registry signed by a private authority host.
You can opt for an external Docker registry only in new installations of Automation Suite. Migrating from the internal Docker registry to an external Docker registry is currently not supported.
OCI compliant registry - A registry implementation that meets the Open Container Initiative specifications. Formerly known as “Docker registry.” There are some widely used implementations, such as Azure Container Registry from Azure and Elastic Container Registry from AWS. In addition, there are self-hosted options such as the former container registry, now found under the Distributions repository.
Artifact - Under the OCI definitions, any image manifest or helm chart manifest hosted in an OCI compliant registry.
- Docker and Helm
as-images.txt
as-helm-charts.txt
mirror-registry.sh
Installing Docker and Helm
You must ensure that you have Docker and Helm installed on the machine from where you plan to upload the Automation Suite container images and Helm charts to your external Docker registry.
- To download the Docker binaries, see the official documentation.
- To download the Helm binaries, see the official documentation.
- To authenticate to the Docker registry, see the official documentation. Alternatively, you can use the following commands by replacing the sample credentials with your actual registry credentials:
docker login my.registry.io:443 --username "admin" --password "secret"
Downloading as-images.txt
as-images.txt
, see Downloading installation bundles.
Downloading as-helm-charts.txt
as-helm-charts.txt
Downloading mirror-registry.sh
mirror-registry.sh
script, see Downloading the installation packages.
mirror-registry.sh
script requires outbound connectivity to the source (default registry.uipath.com
) and target registries.
Command line argument |
Environment variable |
Description |
(Optional) Path to images manifest file. |
(Optional) Path to charts manifest file. |
(Mandatory) Pass the URL for the target registry. |
(Optional) pass the URL for the source registry; default to
registry.uipath.com .
# command line flags style
./mirror-registry.sh --target-registry-url my.registry.io:443 --source-registry-url registry.uipath.com --images-manifest /home/myuser/as-images.txt --helm-charts-manifest /home/myuser/as-helm-charts.txt
These steps are needed only if you use Computer Vision. You can perform these steps at any point in time before using the product.
To upload the optional Computer Vision images to your external Docker registry, take the following steps:
The following images are available for the Computer Vision Models:
aicenter/python36cv:v21.10.0-2
aicenter/python36cvv3:23.4.0-rc19
aicenter/cv2304:23.4.5.6
These steps are needed only if you use Document Understanding. You can perform these steps at any point in time before using the product.
To upload the optional Document Understanding images to your external Docker registry, take the steps in the Document Understanding documentation.
