Automation Suite
- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Migrating from Canal to Cilium CNI
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
Important:
This step is only required when performing a manual upgrade from Automation Suite 2021.10.
To reduce the time required for a Canal to Cilium migration, you can skip the prerequisite check when running
install-uipath.sh
using the-- skip-pre-reqs
parameter.
To migrate from Canal to Cilium, take the following steps on all the machines in the cluster. Make sure to perform this operation on one node at a time.
