test-manager
  • Getting started
    • About this guide
    • About installation
  • Hardware and software requirements
  • Installation and upgrade
Test Manager installation guide
Last updated Apr 22, 2026
Troubleshooting
If you run into installation or upgrade issues, consider the following troubleshooting scenarios:
Failed to create temp directory
Description: When you install or upgrade to this version, the process fails with the following error message: "SFXCA; Failed to create temp directory. Error code 5".
Solution: Run the Test Manager installer with administrative privileges. To do this, open the Command Prompt on your machine where you intend to perform the installation. Execute the following command: UiPathTestManager.msi/l*vx log.txt. This command installs Test Manager while creating a detailed log file (log.txt) which helps in troubleshooting, if issues occur during installation.
The following Windows features need to be enabled in Windows settings
You might run into this installation error if you have missing IIS modules.
docs image
To solve this issue, make sure that you have installed all the IIS modules. For more information, see Software Requirements and Prerequisites.
You don't have the necessary rights to access this application
Important:
Make sure that you have allocated a Testing Runtime license at the tenant level.
If you have previously logged in using the host tenant, you need to change it to Default.
  1. You get the following message if the tenant is set to host.
    docs image
  2. Click the logout button.
  3. Go to Change to specify the tenant.
    docs image
  4. In the Tenant Name enter Default as your tenant.
  5. Enter your credentials and click Log in.
The Following Windows Features Need to Be Enabled in Windows Settings
docs image
You Don't Have the Necessary Rights to Access This Application
Important:
    docs image
    docs image
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
