test-suite
2022.4
- Getting Started with Test Suite
 - Studio
 - Orchestrator
 - Testing robots
 - Test Manager
The Test Suite guide has been deprecated. For the latest documentation on Test Manager and UiPath testing capabilities, visit the Test Manager guide.
Test Suite User Guide
Last updated Sep 9, 2025
This section describes the Mobile Device Automation solution in more detail, and helps you in getting started on how to use it.
Mobile device automation involves using three
               distinct components:
         - Studio - IDE for designing mobile tests, and prepare them for test management and execution.
 - Mobile Automation activities - Configurable actions that you can take on the mobile device, to automate it.
 - MDM (Mobile Device Manager) - Tool that offers you a realistic visual interface of testing and automating a mobile device within Studio. You can use MDM to connect to real or emulated devices through Appium, and perform and record your actions on the device as well as manage devices and applications.
To get started with using UiPath®'s mobile device automation solution, check out the following resources:
- Mobile Automation
 - Mobile Device Manager:
