solutions-management
  • Introduction
    • Getting started
    • Understanding the solution development lifecycle
    • Solution components - Studio Web and Orchestrator
    • Overview of the Solutions UI
    • Developing automations with and without solutions
    • Solutions feature availability
  • Managing solution projects and packages
  • Managing solution deployments
  • Best practices
Solutions user guide
Getting started
Permissions for Solutions
Access to Solutions is controlled through Orchestrator roles. To work with solutions, a user must be assigned an appropriate tenant-level role in Orchestrator. Solutions permissions are not granted automatically. An administrator must assign the following required roles to each user or group:
  • Solutions Administrator
  • Solutions Contributor
Both roles provide access to the Solutions experience in Orchestrator. The level of control depends on the role assigned.
Note:
Because Solutions is a tenant-level feature, assigning only folder-level permissions is not sufficient. The user must be assigned the appropriate tenant role.
Role capabilities
The Solutions Administrator role provides full control over solutions at the tenant level, including both packaging and deploying. The Solutions Contributor role is limited to managing solution packages and does not include deployment capabilities.
Solutions AdministratorSolutions Contributor
  • Create and edit solution projects
  • Upload and manage solution packages
  • Deploy solutions
  • Configure deployments
  • Activate and deactivate deployments
  • Upgrade or change deployment versions
  • Uninstall deployments
  • View and manage deployment logs
  • Manage solution-related configurations
Accessing the Solutions tab in Orchestrator
Note:
When you start building Solutions directly in Studio Web, you need permissions on the Studio Web side. For more information, see the Studio Web user guide.
To access the Solutions tab through Orchestrator, do the following:
  1. Navigate to your Tenant context in Orchestrator.
  2. Select the Solutions tab.
  • Permissions for Solutions
  • Role capabilities
  • Accessing the Solutions tab in Orchestrator
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
