robot
2026.10
Robot admin guide
Networking troubleshooting
Solutions for Robot network issues, including mapped drive failures in unattended mode and assembly loading errors from network or Azure file shares.
Unattended robot cannot find mapped drive​
Description​
Occasionally, robots cannot find a mapped network drive when running unattended automation, especially when running background processes.
Potential issue​
This can happen due to the non-interactive nature of the Windows logon session.
Solution​
Map the network drive in the headless mode for every job the robot starts by running the following command:
net use Z: \\unc\path
When you restart the machine, you must map the network drive in the headless mode again.
Assembly cannot be loaded from network or Azure file share​
Description​
Trying to run a package from a network path or an Azure File Share fails with the "System.Xaml.XamlObjectWriterException: Cannot create unknown type [....]" error.
The robot logs the following error message: "System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the.NET Framework."
Potential issue​
The Robot machine might not trust the web address for the Azure File Share, where the package is located. Alternatively, the account the robot uses might lack permissions for that specific location.
Solution​
Verify that the account under which the robot runs has the necessary permissions. Then, add the Azure File Share web address as a trusted network on the robot machine.
Unresponsive robot over RDP​
Description​
The Robot machine becomes unresponsive and shows high CPU usage at some point after starting the automation. It occurs on Windows 10 v1903 machines.
Potential issue​
This is a Microsoft known issue on Windows 10 v1903 which affects the runtime of the DWM.exe file, leading to high CPU usage upon completion of a Remote Desktop session.
Solution​
Apply the KB4522355 update on the faulty Windows machine.
Connect
Stay updated
