robot
2026.10
Robot admin guide
Installing the Robot
Install, modify, and uninstall UiPath Robot 2026.10 on Windows with the UiPath Platform Installer, in service mode or user mode, on the Enterprise LTS (26.10 line) update channel.
The UiPath Platform Installer installs the Robot on Windows, and keeps it up to date on the update channel you install from. To stay on Robot 2026.10, install from the Enterprise LTS (26.10 line) channel, which receives patch updates for 2026.10 only. Automatic updates are off by default on this channel. For details about the channels, refer to Update channels.
The install scope and the Robot type option decide the Robot's install mode:
Install scopeRobot typeInstall modeUse it for
Per-machine, for all usersUnattendedService modeUnattended automation
Per-machine, for all usersAttendedUser modeAttended automation for every user who signs in to the machine
Per-user, for the current user onlyNot offeredUser modeAttended automation for one person
For how the two modes differ, refer to Service mode and user mode.
Prerequisites​
  • A machine that meets the prerequisites, including the hardware and software requirements.
  • The UiPathPlatformLTS.26.10.msi installer for the Enterprise LTS (26.10 line) channel, available at https://download.uipath.com/connected-installer/latest/lts-26-10/UiPathPlatformLTS.26.10.msi.
  • Administrator rights, for a per-machine installation.
Installation scope​
The Platform Installer installs either for the current user or for all users of the machine:
ScopeDefault installation folderAdministrator rights
Per user%LocalAppData%\Programs\UiPathPlatformNot required
Per machine%ProgramFiles%\UiPathPlatformRequired
When an administrator runs the installer interactively, it installs per machine. To install per user as an administrator, run the installer from the command line with FORCE_PERUSER=1. Refer to Install from the command line.
Install the Robot​
  1. Run UiPathPlatformLTS.26.10.msi. To install per machine, run it as an administrator.
  2. Select Robot in the list of desktop clients. For attended use, also select Assistant. Assistant is a separate card that depends on the Robot, so selecting it selects the Robot too. The Robot installs without Assistant when you select only the Robot.
  3. Select Advanced configuration, then Robot, and set the options you need. For a per-machine installation, select the Robot type: Unattended for service mode, or Attended for user mode.
  4. Select Install and follow the prompts to finish the installation.
For the installer's own options, channels, and screens, refer to Install the desktop clients.
Result​
The Robot is installed on the Enterprise LTS (26.10 line) channel. The Platform Installer downloads the full client builds the first time, and later installs the 2026.10 patch updates. For how and when updates install, refer to Updating the Robot.
Connecting at install time works only for a per-machine installation with the Unattended robot type, and needs the Service URL, Client Id, and Client Secret. The connection is best effort: after installing, check that the robot is connected in Assistant or on the Machines page in Orchestrator. If it isn't, connect the Robot to Orchestrator.
Offline installer​
An offline, all-in-one installer, UiPathPlatformOffline.exe, is also available at https://download.uipath.com/connected-installer/latest/lts-26-10/UiPathPlatformOffline.exe. The offline installer doesn't connect to an update channel.
To update an offline installation, run a newer UiPathPlatformOffline.exe. For the parameters the offline installer supports, refer to Offline installer.
Robot options​
The Robot settings in the Platform Installer offer the following options. A silent installation sets the same options through the parameter in the second column.
OptionSilent installation parameterDescription
Robot typeREGISTER_ROBOT_SERVICEPer-machine installations only. Unattended registers the Robot Windows service (service mode). Attended doesn't (user mode).
Service URLSERVICE_URLThe Orchestrator URL. Required when you set Automatically sign in, or a client ID and client secret.
Client Id and Client SecretORCHESTRATOR_CLIENT_ID, ORCHESTRATOR_CLIENT_SECRETUnattended robots only. With the Service URL, the installer connects the Robot to Orchestrator with client credentials.
Automatically sign inORCHESTRATOR_AUTO_SIGNINAttended robots only. Signs the user in to the Service URL with their own account. Can't be combined with client credentials.
License codeLICENSE_KEYOptional. Activates a Robot license on the machine without Orchestrator.
Default download locationPACKAGES_FOLDERPer-machine installations only. The folder the Robot downloads process packages to.
Disable online feedsNUGET_OPTIONSStops the Robot from using the online activity feeds.
UiPath JavaScript Robot Add-onINSTALL_ROBOTJSInstalls RobotJS. Selected by default for an attended robot, and cleared by default for an unattended robot. Changing the Robot type resets it.
Live streaming and remote controlINSTALL_LIVE_STREAMINGInstalls the RealVNC components used for live streaming and remote control. Off unless you select it.
Automatically Start Assistant with WindowsASSISTANT_STARTUPStarts UiPath Assistant when the user signs in to Windows. Shown only for a per-machine installation with the Attended robot type.
Disable secured XAMLsDISABLE_SECURE_XAMLTurns off XAML protection. XAML protection applies only to robots in service mode that run Windows - Legacy projects.
Enforce signed executionENFORCE_SIGNED_EXECUTIONRuns only signed packages. Refer to Package signature verification.
Browser extensions aren't a Robot option. They are a separate product in the Platform Installer, which you select next to the Robot.
Install folder​
The Robot installs to its own folder, separate from Studio:
  • Per-machine: %ProgramFiles%\UiPathPlatform\Robot\<version>
  • Per-user: %LocalAppData%\Programs\UiPathPlatform\Robot\<version>
The <version> folder name is the Robot package version, such as 26.10.0-<suffix>.<build>, and it changes with every update. To find the current folder, read the RobotDir registry value under HKLM\SOFTWARE\UiPath\UiPath Studio for a per-machine installation, or HKCU\SOFTWARE\UiPath\UiPath Studio for a per-user installation. It always points to the current version folder.
Tools that ship with the Robot, such as UiRobot.exe and UiPath.LicenseTool.exe, are in that folder.
Deploying to multiple machines​
To install without prompts, refer to Silent installation. To install the Robot on many machines, refer to Deploying the Robot to multiple machines.
To control the update channel, the maximum version, and update postponement on those machines, use Group Policy. Refer to Deploy governance policies.
Modify or uninstall the Robot​
The UiPath Platform Installer installs and maintains the Robot together with the other UiPath desktop clients on the machine.
Modify the Robot​
To change the desktop clients or the Robot options installed on a machine:
  1. Open Settings > Apps > Installed apps in Windows and select UiPath Platform > Modify, or run the latest installer from your update channel.
  2. Select the components and options you need.
Changing the Robot type switches the Robot between service mode and user mode. Refer to Switching between modes.
To make the change on several machines, run the installer from the command line. Refer to Silent installation.
Remove or add the .NET 8 runtime​
From 2026.10.1, you can remove the .NET 8 runtime from a machine, or add it back. For what runs on .NET 8, refer to .NET 8 runtime.
  1. Open Settings > Apps > Installed apps in Windows and select UiPath Platform > Modify.
  2. Select Advanced configuration, and then select Runtimes.
  3. Clear .NET 8 runtime to remove it, or select it to add it back.
  4. Select Modify.
The installer removes or adds only the .NET 8 runtime, and leaves the desktop clients as they are.
A silent installation run again with a different INSTALL_NET8_RUNTIME value doesn't add or remove .NET 8. To change the setting without the installer window, uninstall the desktop clients, and then install them again with the new value.
Uninstall the Robot​
  1. Open Settings > Apps > Installed apps in Windows.
  2. Locate UiPath Platform, and then select Uninstall.
Uninstalling the UiPath Platform Installer removes the desktop clients it installed, including the Robot and Studio. To go back to the classic MSI, refer to Migrate from the classic MSI.
Uninstalling doesn't remove the following:
  • The settings in the %ProgramData%\UiPath, %LocalAppData%\UiPath, and %AppData%\UiPath folders
  • The packages folder, %UserProfile%\.nuget\packages
  • The NuGet cache folder, %LocalAppData%\NuGet\v3-cache
Other operating systems​
Connect
Stay updated
