robot
2025.10
Robot admin guide
Recording and Remote Control troubleshooting
Solutions for RDP and screen recording issues in UiPath Robot, including minimized RDP window interference with UI Automation.
Minimized RDP window interference​
RDP connection applications use different techniques to optimize resource consumption. One technique consists in disconnecting the remote display buffer when the RDP application is minimized. This may lead to issues with UI Automations, screen recording, or remote control. You can prevent these issues by disabling the resource consumption optimization.
To achieve this, edit the Remote Desktop registry settings on all computers connecting to the Robot via RDP, but not on the Robot machine. You need administrator privileges to perform the following steps:
  1. Close any active Remote Desktop sessions.
  2. Open the Registry Editor window.
  3. Navigate to the following Registry keys:
    • For the current user:
      • HKEY_CURRENT_USER\Software\Microsoft\Terminal Server Client (32 bit)
      • HKEY_CURRENT_USER\Software\Wow6432Node\Microsoft\Terminal Server Client (64 bit)
    • For all users on the machine:
      • HKEY_LOCAL_MACHINE\Software\Microsoft\Terminal Server Client (32 bit)
      • HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Terminal Server Client (64 bit)
  4. For every key, create a new DWORD (32-bit) value, and rename it to "RemoteDesktop_SuppressWhenMinimized".
  5. Modify the previously created DWORD value: in the Value data field, write 2.
  6. Select OK to save the changes.
  7. Close the Registry Editor window.
  8. Sign off all users from the Robot machine before executing a job. You can now automate UI actions even when the RDP window is minimized.
RealVNC missing component​
Description​
Upon upgrading your Robot installation via existing scripts, you may encounter the following error: "Robot installation missing component: RealVNC".
Potential issue​
This can happen due to the introduction of the LiveStreaming parameter. To use the live streaming feature, you must add this parameter to the ADDLOCAL command.
If you did not update your installation scripts to include the LiveStreaming parameter, the update installs the Robot without the RealVNC capabilities.
Solution​
Starting with version 2024.10, the live streaming feature uses the RealVNC software, which comes bundled in the UiPath Robot and UiPath Studio 2024.10+ installers. Installing or upgrading to the 2024.10+ Robot using the GUI or the command prompt automatically installs RealVNC , unless the ADDLOCAL parameter is used.
If you choose to use the ADDLOCAL parameter in a command prompt installation, you must add the LiveStreaming flag.
For example, the following UiPathRobot.msi command performs a custom installation or upgrade which also installs RealVNC, the software that is required for live streaming:
UiPathRobot.msi ADDLOCAL=Robot,RegisterService,LiveStreaming
  • Minimized RDP window interference​
  • RealVNC missing component​
  • Description​
  • Potential issue​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
