robot
2022.4
Robot User Guide
User Access Control Prompt and UI Automation Activities
Observed Behavior​
Unattended processes using UIAutomation activities such as click, type into or take screenshot do not work.
Cause​
A program such as Server Manager set to launch at start up which displays a Windows User Account Control prompt blocks the Robot from making any interaction with the UI. This is happening because the User Account Control prompt is opened in a separate windows desktop to which the Robot does not have access to.
Resolution​
Manually or programmatically find the program that displays the UAC prompt and set it to not start automatically to avoid the UAC.
  • Observed Behavior​
  • Cause​
  • Resolution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
