- Release notes
- Getting Started
- UiPath Assistant
- Installation and Upgrade
- Robot Types
- Robot Components
- Licensing
- Connecting Robots to Orchestrator
- Processes and Activities
- Logging
- Robot JavaScript SDK
- Specific Scenarios
- Windows Sessions
- Login Using Thales Luna Credential System
- Login Using NShield Key Storage Provider
- Redirecting Robots Through a Proxy Server
- Executing Tasks in a Minimized RDP Window
- Using Mapped Network Drives
- Stopping a Process
- Disable Stop Button
- Custom Package Folders and Network Paths
- CrowdStrike Integration
- Restarting Robot Components
- Governance
- Troubleshooting
- About Troubleshooting
- Unresponsive Robot Over RDP
- Duplicate Execution Logs
- Frequently Encountered Robot Errors
- Increased Process Execution Duration
- Enforced Package Signature Verification
- Message Too Large to Process
- Errors When Running as Administrator
- NuGet Packages Not Accessible After Migration
- User Access Control Prompt and UI Automation Activities
Starting with v2020.10 UiPath integrates nShield Key Storage Provider, making it possible for Unattended Robots to log into Windows by using the nShield Key Storage Provider. nShield is a key storage which provider which allows enterprises, and not only, to provide an extra layer of security when logging into Windows by using the keys stored in the HSM.
Activating this type of login requires a few configuration steps in Orchestrator and on the machine on which the Unattended Robots connect to.
Orchestrator Configuration
Create an Unattended Robot as described in the Managing Users document with the user specifications for which you want to activate nShield login.
1.1. From the Credential Type drop-down, select nShield Key Storage Provider.
1.2. Provide the PIN required to access the HSM in the Password field.
Create a Machine in Orchestrator. Please note that the machine on which the Unattended Robot runs needs to have access to the HSM, which means they should be in the same network.
