- Notas de Versão
- Introdução
- Acesso e permissões
- Interação com o Insights
- Exportação de dados históricos
- Logs
- Desempenho e escalabilidade
2022.10.0
The Insights team is excited to present a new release.
To give you a brief overview, 2022.10 comes with two new Templates, the ability to restrict user data by the folders they have permissions to in Orchestrator, improvements to existing templates to provide additional metrics for measuring your automation program, reduced installation complexity via scripts, and the ability to export historical modeled data to external tools to user for analysis and dashboard.
If you've tried Cloud Insights, you might recognize some of the updates.
You can now keep track of your automation benefits outside of Insights using your own reporting tools such as Power BI, Tableau, etc. Export historical Insights data covering Jobs, Queues, Robot Logs, Process Manual Values, and Queue Manual Values to add it to your business data. The data export is done through a SQL Server Integration Services (SSIS) package that you need to deploy and configure in your environment.
A new template to calculate ROI based on transactions via queues is now available.
Consulte Filas de ROI de negócios
Agora você pode capturar um instantâneo de sua força de trabalho robótica e do uso de RPA assistido por meio do modelo de relatório assistido. Para um mergulho mais profundo nas métricas, consulte este blog escrito pela equipe de produtos do Insights .
Insights installation time has been trimmed down by adding two scripts covering the initial steps for preparing the Linux and Windows environments.
You can now choose to enable a tenant-level setting that restricts the data that Insights users can access based on the folders they have access to in Orchestrator. Use this feature to make sure that users are only able to view data that's relevant to them.
Para impor restrições de dados com base nas permissões de pasta do Orchestrator, consulte Permissões de pasta
Long running workflows are now supported through a new Jobs measure called Total Suspended Time in Seconds. You can use this measure to report the accurate robot utilization time for a long running job. For example, you can measure a job’s total runtime by subtracting the time spent in Suspended state from the job duration in seconds.
Additionally, Time in Pending in Seconds now includes the time a job spends between the Resumed state and the In Progress state.
O modelo de ROI de negócios agora subtrai o tempo que um trabalho gastou no estado Suspenso de cada visualização no painel para oferecer suporte a fluxos de trabalho de longa execução.
Robot Logs Raw Message será preterido e não terá mais suporte a partir da versão 2023.4 (consulte a linha do tempo de descontinuação do Insights).
The deployment configuration of an Insights installation connected to an Orchestrator installed as PaaS on Azure App Service is now supported. The Insights feature can now be enabled as a parameter when you run the Orchestrator scripts to install Orchestrator on an Azure App Service.
-insightsFeatureEnabled
nos scripts do orquestradorO Insights foi testado em escala para fornecer métricas para ingestão de dados, processos em segundo plano e tempos de carregamento do painel. Você pode revisar o Desempenho e a escalabilidade.
Recomendamos que você verifique regularmente o cronograma de descontinuação para obter quaisquer atualizações relacionadas a funcionalidades que serão descontinuadas e removidas.
