- Overview
- Requirements
- Upgrade
- Troubleshooting
- Installation issue with port 53
- Failed initial Redis installation
- Firewall blocking HTTP connections
Linux reserves port 53 for DNS servers. Sometimes, the installation of High Availability Add-on (HAA) might fail because port 53 is already in use. This happens because HAA includes its own DNS server that needs port 53 open.
It is common for some Linux systems to have a DNS server running by default. To ensure a successful HAA installation, these servers need to be disabled. If you are using Ubuntu Linux, the DNS server is typically systemd-resolved, while on RHEL, it is likely to be dnsmasq.
The following sections provide instructions on how to deactivate the DNS servers.
Solution for Ubuntu Linux
To deactivate the systemd-resolved service, refer to the Redis documentation.
Solution for RHEL
To deactivate the dnsmasq service, take the following steps:
If the service is running, stop it:
sudo systemctl stop dnsmasqsudo systemctl stop dnsmasq -
After stopping the service, you must disable it to prevent it from starting automatically on system reboot:
sudo systemctl disable dnsmasqsudo systemctl disable dnsmasq -
Mask the service to prevent it from being started manually or by any other service:
sudo systemctl mask dnsmasqsudo systemctl mask dnsmasqWhen the service is masked, it cannot be started, even if another service or script tries to initiate it.
Verify that the service is no longer active and does not start on the following system reboot:
sudo systemctl status dnsmasqsudo systemctl status dnsmasq
