- Notes de publication
2.2510.3
2.2510.3 release notes for Solutions Management in Automation Suite.
Date de publication: 23 juillet 2026
Améliorations
Affichage précis de la dernière opération pour les déploiements avec activation
When installing or upgrading a solution with the Activate option enabled, the Last operation column in the Deployments table now shows the correct operation. Previously, it could show Activation Setup instead of Install (or Upgrade / downgrade) when activation setup ran in the same session as the deployment; it now consistently reflects the original operation regardless of whether activation setup was needed.
Pour plus d'informations, consultez Statuts de déploiement.
Ressources de l'espace de travail personnel masquées dans les déploiements externes
Personal Workspace resources are no longer offered as candidates when you configure a deployment located outside your Personal Workspace, which prevents broken setups when collaborating with others.
When linking or replacing a resource on a deployment in a shared folder (or any folder outside your Personal Workspace), resources stored at any depth in your Personal Workspace are excluded from the candidate list; when the deployment is inside your Personal Workspace, all your accessible resources, including Personal Workspace ones, remain available.
Pour plus d'informations, consultez Déployer une solution.
Résolution de bogues
We fixed an issue where upgrading a solution deployment could fail when the new package version included resources already installed by the current deployment. The system now detects these conflicts early and surfaces a clear error identifying the affected resources.
