orchestrator
2025.10
Guide d'installation d'Orchestrator
- Démarrage
- Prérequis
- Meilleures pratiques
- Mise à jour en cours
- Serveur d'identité
- Résolution des erreurs de démarrage
- Exceptions Orchestrator
- Exceptions Identity Server
- Exceptions des webhooks
- Resource Catalog exceptions
Common Resource Catalog Service exceptions encountered during startup, including Ledger subscriber errors caused by SQL Server unavailability.
500.30 ASP.NET Core app failed to start - UiPath.ResourceCatalogService.Web.Api.Ledger.LedgerServiceException: Ledger subscriber ResxSubscriber could not be started
Exception
Exception Info: UiPath.ResourceCatalogService.Web.Api.Ledger.LedgerServiceException: Ledger subscriber ResxSubscriber could not be started.
This exception is typically preceded in the Application event log by a Microsoft.Data.SqlClient.SqlException (error 40) and a "SQL Server is shutting down" entry.
Astuce :
Check the Application event log for a SQL connection error immediately before the Ledger subscriber exception to confirm the cause.
Origine
SQL Server was not available when Resource Catalog attempted to start the ResxSubscriber Ledger subscriber. This happens when SQL Server runs on the same machine as Orchestrator and has not finished starting when Orchestrator starts after an OS restart.
Solution
- Confirm that SQL Server is running and accepting connections.
- Stop the Orchestrator site in IIS Manager.
- Start the Orchestrator site in IIS Manager.
