automation-cloud
Guide d'administration d'Automation Cloud
Dernière mise à jour 30 mars 2026
External client - Federated credentials
Federated credentials let an OAuth external application authenticate to UiPath using a JSON Web Token (JWT) issued by an external identity provider, without requiring a client secret. Each application supports a maximum of 20 federated credentials.
Use the endpoints on this page to list, create, retrieve, update, and delete federated credentials for a registered OAuth external application. To manage external applications themselves, see Managing external OAuth applications.
List federated credentials
Retrieve all federated credentials registered for a specific OAuth external application.
Point de terminaison de l’API
GET
          {accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentialsGET
Paramètres de chemin d'accès
ParamètreDescription
partitionGlobalIdThe organization global ID.
clientIdThe ID of the OAuth external application.
Étendues
Nécessite l’une des étendues suivantes :
  • PM.OAuthApp
  • PM.OAuthApp.Read
En-têtes de requête.
--header 'Authorization: Bearer {access_token}'--header 'Content-Type: application/json'
Note: To obtain the {access_token}, use an organization administrator token or authenticate through one of the methods described in Authentication methods.
Réponses
200 OK
Returns an array of FederatedCredentialDto objects. Returns an empty array if no credentials are registered.
Exemple de requête
curl --request GET \
  '{accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentials' \
  --header 'Authorization: Bearer {access_token}'curl --request GET \
Exemple de réponse
[{"id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","clientId":"1539a53a-e34f-4803-adef-b9cd82f18858",
"name":"GitHub Actions","description":
"Used for GitHub Actions CI/CD pipeline","issuer":
"https://token.actions.githubusercontent.com","audience":"https://cloud.uipath.com/myorg",
"subject":"repo:myorg/myrepo:ref:refs/heads/main",
"createdAt":"2026-03-01T10:00:00Z",
"updatedAt":"2026-03-01T10:00:00Z"}][{"id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","clientId":"1539a53a-e34f-4803-adef-b9cd82f18858",
Create a federated credential
Create a federated identity credential for a specific OAuth external application.
Note: Each application supports a maximum of 20 federated credentials.
POST
          {accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentialsPOST
Étendues
  • PM.OAuthApp
  • PM.OAuthApp.Write
--header 'Authorization: Bearer {access_token}'--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'--header 'Content-Type: application/json'
Corps de la requête
{"name":"azure-production-workload","description":"Federated credential for production Azure workload",
"issuer":"https://login.microsoftonline.com/{tenant-id}/v2.0",
"audience":"api://uipath-production","subject":"00000000-0000-0000-0000-000000000000"}{"name":"azure-production-workload","description":"Federated credential for production Azure workload",
ChampRequisDescription
nameOui (Yes)A descriptive name for the credential. Must be unique within the application. Maximum 128 characters.
descriptionNon (No)Optional context for the credential. Maximum 512 characters.
issuerOui (Yes)The HTTPS URI of the external identity provider. Must be reachable at create time.
audienceOui (Yes)A single string that must appear in the JWT aud claim.
subjectOui (Yes)A value that must exactly match the JWT sub claim.
Réponses
201 Créé
Returns the created FederatedCredentialDto object.
400 Requête incorrecte
The request is invalid. Possible causes: name is not unique within the client, issuer is not a valid HTTPS URI, the issuer's JWKS endpoint is unreachable, or the maximum of 20 credentials per application has been reached.
404 Not Found
The specified clientId does not exist or does not belong to the caller's organization.
Exemple de requête
curl --request POST \
  --header 'Authorization: Bearer {access_token}' \
  --header 'Content-Type: application/json' \
  --data '{"name":"GitHub Actions","description":"Used for GitHub Actions CI/CD pipeline","issuer":"https://token.actions.githubusercontent.com","audience":"https://cloud.uipath.com/myorg","subject":"repo:myorg/myrepo:ref:refs/heads/main"}'
Exemple de réponse
"1539a53a-e34f-4803-adef-b9cd82f18858","name":"GitHub Actions","description":
"createdAt":"2026-03-01T10:00:00Z","updatedAt":"2026-03-01T10:00:00Z"}{"id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","clientId":
Get a federated credential
Retrieve a specific federated credential by its ID.
GET
          {accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentials/{credentialId}GET
credentialIdThe ID of the federated credential.
Étendues
  • PM.OAuthApp
  • PM.OAuthApp.Read
Réponses
200 OK
Returns the FederatedCredentialDto object for the requested credential.
404 Not Found
The specified credential or application does not exist in the caller's organization.
Exemple de requête
  '{accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentials/{credentialId}' \
Example response
"https://cloud.uipath.com/myorg","subject":"repo:myorg/myrepo:ref:refs/heads/main",
"createdAt":"2026-03-01T10:00:00Z","updatedAt":"2026-03-15T08:30:00Z"}{"id":"3fa85f64-5717-4562-b3fc-2c963f66afa6","clientId":"1539a53a-e34f-4803-adef-b9cd82f18858",
Update a federated credential
Update an existing federated credential. All required fields must be included in the request body.
PUT
          {accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentials/{credentialId}PUT
credentialIdThe ID of the federated credential to update.
Étendues
  • PM.OAuthApp
  • PM.OAuthApp.Write
Corps de la requête
{"name":"azure-production-workload-updated","description":"Updated description","issuer"
:"https://login.microsoftonline.com/{tenant-id}/v2.0","audience":
"api://uipath-production","subject":"00000000-0000-0000-0000-000000000000"}{"name":"azure-production-workload-updated","description":"Updated description","issuer"
Réponses
200 OK
Returns the updated FederatedCredentialDto object.
Validation failed. Possible causes: duplicate name, invalid issuer URI, or unreachable JWKS endpoint.
Exemple de requête
curl --request PUT \
  --data '{"name":"GitHub Actions — Production","description":"Production branch deployments only","issuer":"https://token.actions.githubusercontent.com","audience":"https://cloud.uipath.com/myorg","subject":"repo:myorg/myrepo:ref:refs/heads/main"}'
Exemple de réponse
"clientId":"1539a53a-e34f-4803-adef-b9cd82f18858","name":"GitHub Actions — Production","description":
"audience":"https://cloud.uipath.com/myorg","subject":"repo:myorg/myrepo:ref:refs/heads/main",
"createdAt":"2026-03-01T10:00:00Z","updatedAt":"2026-03-20T14:00:00Z"}{"id":"3fa85f64-5717-4562-b3fc-2c963f66afa6",
Delete a federated credential
Delete a federated credential. This action is permanent and immediately invalidates any token acquisition using this credential.
Warning: Deletion is permanent. After deletion, the credential can no longer be used to acquire new access tokens. Access tokens already issued before deletion remain valid until they expire.
DELETE
          {accessURL}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}/FederatedCredentials/{credentialId}DELETE
credentialIdThe ID of the federated credential to delete.
Étendues
  • PM.OAuthApp
  • PM.OAuthApp.Write
Réponses
204 Aucun contenu
The federated credential was deleted successfully. The response body is empty.
404 Not Found
Exemple de requête
curl --request DELETE \
  --header 'Authorization: Bearer {access_token}'curl --request DELETE \
Acquire a token using a federated credential
Exchange a JWT from your external identity provider for a UiPath access token.
POST {accessURL}/identity_/connect/token
Request headers
--header 'Content-Type: application/x-www-form-urlencoded'
Request body
grant_type=client_credentials
&client_id={client_id}&client_assertion_type=urn:ietf:params:oauth:client-assertion-type:jwt-bearer
&client_assertion={jwt_token}&scope={requested_scopes}grant_type=client_credentials
grant_typeMust be client_credentials.
client_idThe client ID of the registered OAuth external application.
client_assertion_typeMust be urn:ietf:params:oauth:client-assertion-type:jwt-bearer.
client_assertionThe JWT issued by your external identity provider.
scopeThe OAuth scopes requested for the access token.
Réponses
200 OK
Returns an access token object. Use the access_token value in the Authorization: Bearer header of subsequent API calls.
Token acquisition failed. Possible causes: JWT signature invalid, issuer or audience mismatch, subject mismatch, expired JWT, or JWT exceeds 8 KB.
Schemas
The object returned by GET, POST, and PUT operations.
PropriétéSaisie de texteNullableDescription
idstring (uuid)Non (No)The unique identifier of the federated credential.
clientIdstringOui (Yes)The application ID of the OAuth external application this credential belongs to.
namestringOui (Yes)The display name of the federated credential.
descriptionstringOui (Yes)The description of the federated credential.
issuerstringOui (Yes)The URL of the external identity provider.
audiencestringOui (Yes)The expected aud claim value in the JWT.
subjectstringOui (Yes)The expected sub claim value in the JWT.
createdAtstring (date-time)Non (No)The UTC timestamp when the credential was created.
updatedAtstring (date-time)Non (No)The UTC timestamp when the credential was last updated.
