automation-cloud
- Démarrage
- Authentification
- Étendues et autorisations
- API de gestion de plate-forme
Guide d'administration d'Automation Cloud
Dernière mise à jour 12 déc. 2025
As an organization admin, use this endpoint to allocate licenses to a group and optionally configure quotas to limit license consumption. Requires an external application with the scope
PM.License.Write.
PUT <https://https://cloud.uipath.com/{organizationName}/lease_/api/account/{accountId}/user-license/group/{groupId}/with-quota>
--header 'Authorization: Bearer {access_token}'
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'
--header 'Content-Type: application/json'| Paramètre du chemin d'accès | Type de données | Description |
(requis) | GUID | L'ID de l'organisation dans laquelle réside votre locataire. |
(requis) | Chaîne de caractères (string) |
L'ID du groupe auquel vous souhaitez attribuer des licences. Vous pouvez récupérer cet ID en suivant ces étapes. |
"userBundleCodes": ["string"],
"quotas": [
"userBundleCode": "string",
"limit": 10
"quotas": [
"limit": 10
}Remarque :
userBundleCodes: Array of license codes to allocate (refer to user license codes).quotas(optional): Quota configurations. EachuserBundleCodein quotas must exist in theuserBundleCodesarray.- Quota
limitmust be at least 1 and cannot be lower than current usage. - If quotas are empty, licenses are allocated without limits.
200 OK
Returns the allocated group licenses with configured quotas and current usage.404
Organization or group does not exist.The request should resemble the following example (cURL):
curl --location --request PUT 'https://https://cloud.uipath.com/{organizationName}/lease_/api/account/1234/user-license/group/group-01/with-quota' \
--header 'Authorization: Bearer {access_token}' \
--header 'Content-Type: application/json' \
--data-raw '{
"userBundleCodes": ["RPADEVPRONU", "IDU"],
"quotas": [
"userBundleCode": "RPADEVPRONU",
"limit": 10
}'curl --location --request PUT 'https://https://cloud.uipath.com/{organizationName}/lease_/api/account/1234/user-license/group/group-01/with-quota' \
--data-raw '{
"quotas": [
"limit": 10
}'Voici le corps de la réponse pour une allocation de licence réussie :
"groupRule": {
"groupId": "group-01",
"organizationId": "1234",
"quotas": [
"limit": 10,
"currentUsage": 3
"groupRule": {
"quotas": [
"limit": 10,
"currentUsage": 3
