Automation Suite API guide
Get settings
Retrieve email and authentication settings for an Automation Suite organization as key-value pairs using the Identity API, including required scope and response schema.
Use this endpoint to retrieve the list of key-value pairs for email and authentication settings.
API endpoint​
GET https://{yourDomain}/{organizationName}/identity_/api/Setting
Scopes​
Requires the following scopes:
  • PM.Setting
  • PM.Setting.Read
Request headers​
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described in Authentication methods.
Query parameters​
ParameterData typeDescription
keyStringOptional.
Enter the name of the setting you want to retrieve.
For example, to retrieve the SMTP Domain setting, enter key=Email.Smtp.Domain.
partitionGlobalIdStringOptional.
The ID of the organization you want to retrieve the settings for.
userIdStringOptional.
The ID of the user you want to retrieve the settings for.
Responses​
200 OK​
Returns the queried robot accounts.
Example request​
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/identity_
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: 3fa85f64-5717-4562-b3fc-2c963f66afa6
  • You want to retrieve the global email settings, so you log in as the host admin. In this case, you don't provide a userID.
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/identity_/api/Setting?partitionGlobalId=3fa85f64-5717-4562-b3fc-2c963f66afa6&key=Email.Smtp.Domain&key=Email.Smtp.EnableSsl&key=Email.Smtp.FromDisplayName&key=Email.Smtp.FromEmail&key=Email.Smtp.Host&key=Email.Smtp.Password&key=Email.Smtp.Port&key=Email.Smtp.UseDefaultCredentials&key=Email.Smtp.UserName' \
Here's the response body for a successful call:
        "id": 6,
        "key": "Email.Smtp.FromEmail",
        "value": "newalerts.uipath@gmail.com",
        "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
        "userId": null
        "id": 7,
        "key": "Email.Smtp.FromDisplayName",
        "value": "Hogwarts server - 21.10 - Clean",
        "userId": null
        "id": 15,
        "key": "Email.Smtp.Domain",
        "value": "",
        "userId": null
        "id": 16,
        "key": "Email.Smtp.EnableSsl",
        "value": "true",
        "userId": null
        "id": 17,
        "key": "Email.Smtp.Port",
        "value": "587",
        "userId": null
        "id": 18,
        "key": "Email.Smtp.UseDefaultCredentials",
        "value": "false",
        "userId": null
        "id": 19,
        "key": "Email.Smtp.UserName",
        "userId": null
        "id": 20,
        "key": "Email.Smtp.Host",
        "value": "smtp.gmail.com",
        "userId": null
        "id": 21,
        "key": "Email.Smtp.Password",
        "value": "protego-spell",
        "userId": null
        "id": 6,
        "userId": null
        "id": 7,
        "userId": null
        "id": 15,
        "value": "",
        "userId": null
        "id": 16,
        "value": "true",
        "userId": null
        "id": 17,
        "value": "587",
        "userId": null
        "id": 18,
        "value": "false",
        "userId": null
        "id": 19,
        "userId": null
        "id": 20,
        "userId": null
        "id": 21,
        "userId": null
  • API endpoint​
  • Scopes​
  • Request headers​
  • Query parameters​
  • Responses​
  • 200 OK​
  • Example request​
Connect
Stay updated
