Automation Suite API guide
Delete users
Delete multiple local users from an Automation Suite organization using the Identity API, including required scope and response codes.
Deletes multiple users from an organization, based on the users IDs.
API endpoint​
DELETE https://{yourDomain}/{organizationName}/identity_/api/User
Scopes​
Requires the following scopes:
  • PM.User
  • PM.User.Write
Request headers​
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described in Authentication methods.
Path parameters​
ParameterData typeDescription
partitionGlobalIdStringRequired.
The ID of the organization you want to retrieve the robot accounts for.
Request body​
The request body contains the list of user IDs you want to bulk delete from the organization.
  "partitionGlobalId": "string",
  "userIds": [
    "string"
  "userIds": [
    "string"
Responses​
204 Success​
The indicated robot accounts are deleted from the organization.
Example request​
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/identity_
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: 3fa85f64-5717-4562-b3fc-2c963f66afa6
  • The users you want to delete have the following IDs:
    • Dolores Umbridge: dol-2908
    • Quirinus Quirrell: qui-2609
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/identity_/api/User' \
--data-raw '{
    "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
    "userIds": [
        "dol-2908", "qui-2609"
--data-raw '{
    "userIds": [
  • API endpoint​
  • Scopes​
  • Request headers​
  • Path parameters​
  • Request body​
  • Responses​
  • 204 Success​
  • Example request​
Connect
Stay updated
