Automation Hub API guide
Permissions Per Endpoint
Admin Console
Note:
The Open API permission system works by the same principles of the one included in the Automation Hub interface.When an API token is generated with a user associated to it, then the permissions of that user will be reflected in the API calls he can perform via the Open API.
ActionPermissionsToken Type
GET - /hierarchyOpen endpoint that can be accessed by all users, regardless of their permissions in the interface.Personal TokenUser Assigned TokenTenant Level Token
GET - /appinventoryOpen endpoint that can be accessed by all users, regardless of their permissions in the interface.Personal TokenUser Assigned TokenTenant Level Token
GET - /usersAll users with the Manage Users permissionPersonal TokenUser Assigned TokenTenant Level Token
POST - /adduserAll users with the Manage Users permissionPersonal TokenUser Assigned TokenTenant Level Token
POST - /edituserAll users with the Manage Users Roles permissionPersonal TokenUser Assigned TokenTenant Level Token
GET - /rolesAll users with the Manage Users rolePersonal TokenUser Assigned TokenTenant Level Token
Automation Ideas
GET - /automationsIs limited based on user's permissions to specific categories. For example: if a user is has a "Standard User" permission that applies to "Legal", GET Automations will display all the automations in "Legal".Personal TokenUser Assigned Token
POST - /automationideaAll users that are allowed to submit Employee Driven ideas as per the permission in the interface.Personal TokenUser Assigned Token the call works only if you define a submitter in the Body
POST - /coe-automationideaAll users that are allowed to submit CoE Driven ideas as per the permission in the interface.Personal TokenUser Assigned Token the call works only if you define a submitter in the Body
POST - /automations/statusAll users that are allowed to Edit details of ideas as per the permission in the interface.Personal TokenUser Assigned Token
GET - /cbaAll users that are allowed to View details of the Cost Benefit Analysis as per the permission in the interface.Personal TokenUser Assigned TokenTenant Level Token
GET - /collaboratorsAll users that are allowed to View Idea Collaborators as per the permission in the interface.Personal TokenUser Assigned TokenTenant Level Token
Automation Pipeline
GET - /automationpipelineAll users that are allowed to View the Automation Pipeline as per the permission in the interface.Personal TokenUser Assigned Token
  • Admin Console
  • Automation Ideas
  • Automation Pipeline
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
