Automation Hub API Guide
- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
GET Automation Pipeline
| Name | Description |
| process_id | ID of the process |
| process_slug | Slug of the idea |
| process_name | Idea Name |
| process_description | Description of the Idea |
| orchestrator_automation_uuid | Idea ID |
| user_department | Submitter's Department |
| user_business_unit | Sbumitter's Business Unit |
| process_goal | Process goal |
| process_phase_id | Phase ID |
| process_phase_status_id | Phase status ID |
| process_overall_gauge_score | Overall idea score |
| process_automation_score | Idea potential |
| process_estimated_benefit_score | Estimated benefit (Hours) |
| software_vendor_id | RPA Software Vendor |
| software_cost_id | Software cost |
| cost_description | Cost Description |
| process_type_id | Idea Type |
| owner | Process Owner |
| process_ease_of_implementation_score | Ease of implementation |
| process_submitter_user_id | Submitter User ID |
| process_submission_type | Idea Submission type |
| process_num_collaborators | Number of collaborators |
| process_num_votes | Number of votes |
| process_created_epoch | The epoch when the process was created |
| process_updated_epoch | The epoch when the process was updated |
| check_collaborators | (internal field) |
| number_of_robots | Number of robots |
| relevance | (internal field) |
| category_id | Idea Area ID |
| category_other_text | Idea Area ID |
| category_name | Idea Area name |
| category_level_id | Idea Area creation time |
| category_is_other | Idea Area created epoch |
| subcategories | Idea Area updated time |
| software_vendor | RPA Software Vendor |
| running_cost | Est. Running Costs |
| process_phase | Idea phase |
| phase_id | Idea phase ID |
| phase_key | Idea phase key |
| phase_name | Idea phase name |
| phase_is_active | Phase is active |
| phase_order | Phase order |
| process_phase_status | Idea status |
| phase_status_id | Idea status ID |
| phase_status_key | Idea status key |
| phase_status_name | Idea status name |
| phase_status_is_active | Idea status is active |
| phase_status_order | Idea status order |
| currency | Currency |
| currency_id | Currency ID |
| currency_name | Currency name |
| currency_abbreviation | Currency abbreviation |
| currency_symbol | Currency symbol |
| currency_is_active | Currency is active |
| currency_sort_order | Currency sort order |
| process_submitter | Idea Submitter |
| user_id | Idea Submitter user ID |
| user_email | Idea submitter e-mail |
| user_first_name | Idea submitter first name |
| user_last_name | Idea submitter last name |
| readable_submission_time | Idea submission time |
| owner | Idea Process Owner |
| user_id | Idea Process Owner user ID |
| user_email | Idea Process Owner e-mail |
| user_first_name | Idea Process Owner first name |
| user_last_name | Idea Process Owner last name |
| pdd_link | PDD Link |
| idea_phase_approver | The person that updated the idea phase |
| launch_assessment_approver | The person that launched the idea assessment |
| qualification_phase_approver |
Automation Ideas
GET Automation Ideas
| process_slug | Slug of the Idea |
| process_submitter_user_id | The DB ID of the submitter of the idea |
| process_description | Description of the idea |
| process_rules_id | Answer to question: How rule based is your task |
| process_input_type_id | Answer to question: How would you describe the input data for your task/process? |
| process_stability_id | Answer to question: Are you aware of any expected changes to the way you currently perform the activity or process in the following 6 months? |
| process_input_structure_id | Answer to question: How would you describe the structure of your input data? |
| process_documentation_availability_ids | Answer to question: Do you have any documentation regarding this process/activity? |
| owner | The DB ID of the Process Owner |
| process_created_at | Timestamp when the process was created |
| process_updated_at | Timestamp when the process was updated |
| process_updated_user_id | The DB ID of the user who last updated the process |
| process_challenges_encountered | Encountered Challenges |
| process_challenges_expected | Expected Challenges |
| process_task_stability_id | Process Changes Expected in the Next 6 Months |
| process_application_stability_id | Applications Changes Expected in the Next 6 Months |
| process_frequency_id | Task/Process Frequency |
| process_volume | Activity Volume Average |
| process_average_handling_time | Average Processing Time/Transaction |
| process_peak_id | Process Peaks |
| process_length_id | Average Number of Steps |
| process_decision_complexity_id | Process Variability |
| process_digital_input_percent | % of Digital Data Input |
| process_scanned_input_use_id | Scanned Data Input |
| process_structured_input_id | % of Structured Digital Data Input* |
| process_lessons_learned | Lessons Learned |
| process_benefits_expected | Expected Benefits |
| process_benefits_actual | Actual Benefits |
| process_suitability_score | Idea Suitability |
| process_readiness_score | Idea Readiness |
| process_uuid | Process Unique ID |
| process_num_followers | Number of Followers of the process |
| process_num_votes | Number of Upvotes |
| process_num_media | Number of Media Uploaded |
| process_num_documents | Number of Documents uploaded |
| process_num_collaborators | Number of Collaborators |
| process_num_components | Number of Components attached |
| process_has_owner | Indicates if the Process Owner has been attached or not to the idea |
| process_num_comments | Number of Comments |
| process_num_applications | Number of Applications used |
| process_automation_score | Idea Potential |
| process_ease_of_implementation_score | Ease of Implementation |
| process_estimated_benefit_score | Benefit (hours saved/year) |
| process_benefit_expressed_in_currency_per_year | Benefit (currency/year) |
| process_east_of_baseline_score | |
| process_num_similar_automations | Number of similar ideas |
| process_is_potential_duplicate | Potential duplicates for the idea |
| process_submitted_at | Timestamp when the process was submitted |
| process_submitted_epoch | Epoch when the process was submitted |
| process_history_version | |
| project_manager_user_id | The ID of the Project Manager attached to the idea |
| process_goal | Idea goal ID |
| process_archived_reason | Reason for archiving the idea |
| process_rejected_reason | Reason for rejection of the idea |
| process_pain_points | Pain points |
| process_negative_impact | Negative impact |
| process_submission_type | Submission type (Coe/Employee driven Idea) |
| process_volumes_per_year | Process Volumetry - Volumes / year |
| process_AHT_employee_per_transaction | AHT employee per transaction (minutes) |
| process_ease_of_implementation_level | One of the 3 Ease of Implementation levels - Easy / Medium / Difficult |
| process_cost_per_year | Running Cost/Year before idea for Human |
| process_automation_id | Idea ID |
| process_business_unit | Idea Business Unit |
| process_department | Idea Department |
| process_headcount | Number of Employees Performing the Task |
| user_is_following | There is a user that follows the idea |
| user_has_voted | There is a user that voted for the idea |
| process_phase | Phase of the status |
| phase_key | Phase key |
| phase_name | Phase name |
| process_phase_status | Process status |
| phase_status_id | Status ID |
| phase_status_key | Status key |
| phase_status_name | Status name |
| phase_status_is_active | Status is active |
| phase_status_order | Status order |
| category_id | ID of the category |
| category_other_text | Text of the category if it was renamed |
| category_name | Name of the category from the interface |
| category_level_id | ID of the level for the category - values from 1 to 5 |
| category_is_other | Indicates if the category is other |
| subcategories | Array for subcategories |
| process_rules_comment | Comment on Rules Question |
| process_input_type_comment | Comment on Input_Type Question |
| process_input_quality_comment | Comment on Input_Quality Question |
| process_stability_comment | Comment on Stability Question |
| process_document_availability_comment | Comment on Document_Availability Question |
| process_submitter | Idea submitter |
| user_id | Idea submitter ID |
| user_email | Idea submitter email |
| user_first_name | Submitter first name |
| user_last_name | Submitter last name |
| process_owner | Idea Process Owner |
| user_id | Idea Process Owner ID |
| user_email | Idea Process Owner email |
| advanced_information | Advanced information |
| currency_is_active | Indicates if the currency is active |
| currency_sort_order | Indicates the sort order of the currency in the currency table |
POST Automation Ideas
| process_name | Idea name |
| process_has_owner | Process Owner defined |
| owner | Process Owner user ID |
| process_input_structure_id | Answer to question: Are you aware of any expected changes to the way you currently perform the activity or process in the following 6 months? |
| process_stability_id | Answer to question: How would you describe the structure of your input data? |
| process_slug | The slug of the idea |
| process_submitted_at | Timestamp when the idea was submitted |
| process_submitted_epoch | Epoch when the idea was submitted |
| process_updated_user_id | User ID of the last user who updated the idea |
| process_updated_epoch | Idea last updated epoch |
| process_updated_at | Idea last updated timestamp |
| process_id | The ID of the process |
| process_num_media | Number of Media uploaded |
| process_automation_id | Automaiton ID |
| user_has_voted | There is a user that voted the idea |
| process_input_type_comment | Comment on Input Type Question |
| process_input_quality_comment | Comment on Input Quality Question |
| process_document_availability_comment | Comment on Document Availability Question |
GET App Inventory
| application_id | Indicates the ID of the application |
| application_name | Name of the application |
| application_taxonomy_L1_id | ID of the Application Category (L1) correspondent to the application |
| application_version | The version of the application |
| application_language | Language of the application |
| application_code | Code of the application |
| application_is_active | Indicates if the application is active |
| application_added_by_end_user | Indicates if the application was added by an end-user |
| application_added_user_id | Indicates the user ID which added the app |
| application_created_epoch | Epoch when the application was created |
| categoryIds | Indicates the IDs of the categories where the app is linked |
GET Hierarchy
| category_name | Name of the category - that appears in the interface |
GET Users
| user_id | Indicates the ID of the user |
| user_email | The e-mail of the user |
| user_first_name | First name of the user |
| user_last_name | Last name of the user |
| user_is_admin | Indicates if the user is the "First user" of the tenant, the user that created the tenant |
| user_job_title | User's Job Title |
| user_location | User's Location |
| user_business_unit | User's Business Unit |
| user_department | User's Department |
| user_created_at | Timestamp when the user has been created |
| user_updated_at | Timestamp when the user has been updated |
| user_last_login_time | User last login time |
| user_num_automations | User's number of ideas |
| user_num_documents | User's number of documents created in the tenant |
| user_num_components | User's number of components |
| user_invite_status | Defines if the user has received an e-mail invitation or not |
| user_is_active | Defines if the user is active or not |
GET Roles
| role_description | The description of the role |
| role_id | The ID of the role |
| role_name | The name of the role |
| role_slug | The slug of the role |
| role_type | The type of role |
